what to do with colored vac lines after EGR and Smog delete
Dan95-5.0
1,110
Manitoba, Canada
i'm removing my EGR and AIR. All the hoses, lines, and valves.
what do i do with the red, green, and tan lines that go into the fenderwell?
do i need these? i know where there connected to but should i just plug the lines or remove them all together?
thanks
You can remove them if you like,(assuming your smog pump is gone) just make sure they are capped off really good. Like stated above, use a large bolt, or screw. You can buy plugs at most local parts stores for a few bucks. Just make sure they are sealed, or you will have a vacuum leak. You don't want that.
