What to do.....
  • Thread starter Thread starter 86ttopmustang
  • Start date Start date Mar 29, 2006
86ttopmustang
51
north babylon
Mar 29, 2006
  • Mar 29, 2006
i bought thhis car a couple of weeks ago, and the things that are done to it or supposedly done to it are listed below in my signature. What is a list of things i should do to it to make it faster/more reliable.
Im very happy right now since it is my first mustang and I believe the stuff done to it is a good start..let me know
Thanks for any input.
whtpny
338
Spokane WA.
Mar 30, 2006
  • Mar 30, 2006
Got any pics? I love those 4 eye cars.
Anyway, it looks like you got a good start on mods.Get rid of that way restrictive 86 intake. I hear they are even worse than the stock 87-93s. Bump your timing depending on the fuel you run. Get some pullies. Pull the air silencer.
Anyway do a search and you eill be looking at things to do to that car all night.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Mar 30, 2006
  • Mar 30, 2006
This list covers all of the basic things that should be looked at / replaced or repaired so you get the most enjoyment out of your car. Some of this stuff is already done on your car so you will have to pick and choose.(Go STANGNET!).
First mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) For AOD people: Get a higher stall converter and a shift kit! (don't forget theTranny cooler)
4) Full Exhuast (headers, hi-flo cats, catback w/ mufflers)
5) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
6) Bumped timing to 12 - 14 degrees (free mod) 10 Degrees is stock.
7) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
8) Better Intake Manifold or a Ported one
9) 3G alternator upgrade / electric fan
10) Fix the stock brakes.
Optional MODs:
11) Strut tower brace (necessary on Convertibles IMO)
12) Underdrive pullies (they can't be used on S/C motors and cause charging problems)
13) Weight reduction out of the nose of the car
14) Shocks/Struts and lowering springs
15) C/C plates if you lower the car
16) Short throw shifter (if you have a manual transmission)
17) Cleaning or replacing all of the sensors (TPS, IAC, etc. - not a mod but it helps)
After those basic mods it will be pretty much up to you to pick a final direction for your car. There are plenty of Super Chargers or H/C/I [Heads, Cam and Intake] packages to choose from to really wake up the car.
Also, don't forget about the basic tune up
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft are prefered
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see first mods item #4
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
Edit: Updated the list...
Euphoric306
905
  • Mar 30, 2006
nice list there srothfuss. just one change though. i think he should consider a better intake manifold to go with the bigger tb (86 was only a 58mm tb instead of 60mm). with the full exhaust he's got, and the "performance cam" the only restriction then would be those e6's
86ttopmustang
51
north babylon
Mar 30, 2006
  • Mar 30, 2006
actually i have no pics on my computer right now but i can tell you the body looks like ****!!! Thats the first thing I am going to do (body work/painted), then i am going to take out and rebuild the engine.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Cyber Truck tried to race me!
  • MKatzenbach
  • Sep 5, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 8, 2026
gkomo
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 3, 2026
Mustang5L5
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
