What to expect?
Mostly stock meaning barely modified? Or Almost stock meaning mostly bolt on parts?
An igntion box doesn't really do anything for performance but will go a long ways in letting your car run better and idle without too much searching.
car should run better, start better and get better fuel economy. Basically on a stock motor it will make it a little more efficient from what I have seen. Are you going to see big horsepower gains. Probably not but if you want to get one and put it in I would look at it as an investment in the future if you plan on modding the car later on.
Your car will run so much better... Later after the H/C/I and supercharger the box will really pay off. It's money well spent if you have the extra money to spend.
I just got my crane box + coil about 2 weeks ago. My car starts so much faster and runs a lot smoother. I just have to wait until spring to tell you how much better the car drives (not faster..... better)
Glad to see its working for you!
As far as what to expect, you won't notice any gains in the 1/4 if you run at the track. Like the others said the car should run better. However, when you do add H/C/I you will then obviously start noticing a huge improvement in the overall performance of the car.
I had both a MSD 6AL and a MSD Digital 6 plus, both failed and when I went back to the stock ignition i did not see any difference at all in performance. and as u can see in the sig is heavily modified.
