What to set FP at?
1992blkGT
523
Beaverton, OR
I just installed the Trick Flow Street Heat H/C/I kit, and I got 24lb injectors, 255lph fuel pump, and a Kirban AFPR. I was just wondering where I should set the fuel pressure at? I was told 30-34psi if I remember correctly, does this sound right? Thanks
With 24# injectors and the stock PCM 37# FP is where you want it. I datalogged this on my NA 306 with 24# injectors using the stock PCM and Tweecer RT. This is assuming your MAF is calibrated for 24# injectors.
Don
Don
What are your mods? I am kind of in the same situation.
Don
Yes, it's an 80mm Pro-M calibrated for 24lb injectors. How can I tell if I'm running rich? I can't afford a dyno tune for awhile, so I'm going to have to tune the FP myself. Thanks for the help!
1992blkgt,
If you have the FP close to 37# the PCM can adjust +/-10% to compensate for errors. The best way to tell if you're running rich is with a WBo2, if you don't have one try smelling your exhaust, it should only smell slightly like fuel when cold, other than that it shouldn't smell like fuel. Check your plugs, the white ceramic should be white if your running Stoich most of the time, however, also check the metal ground bar on the plug it should be tan or light brown indicating that overall you're ok. If you have good o2 sensors the PCM cam learn and correct for proper mixture unless you have a SC or Turbo then things get pretty tough for the PCM to figure out, this is where a WBo2 is mandatory. Also pinging could indicate lean or too much timing.
Good Luck, Don
Mods
Engine: 306 ci NA w/ timing at 18*, Sterling pistons H273CP w/8.9:1 compression, FMS Harmonic balancer, Edelbrock 6037 heads w/2.02" intake valves, Edelbrock performer intake manifold, FMS 1.6 roller rockers, Crane 444221 (2030) 216/220 @ 0.05" with 112 lobe separation 0.533"/0.544" lift, FMS aluminum radiator, Lincoln Mark VIII electric fan, Performance Distributors TFI and Screem’n Demon coil, FMS 9mm plug wires.
Fuel and Air: 24# FMS injectors, Edelbrock 70mm TB, C&L 73mm MAF, stock fuel pressure regulator, 195 lph fuel pump, MAC CAI.
Exhaust: 1 5/8" BBK ceramic coated headers, MagnaFlow SS 2 1/2” catback and X-pipe w/Cats.
Drive Train: D&P Products 2500 RPM stall 9 1/2” torque converter w/damper, AOD w/ TransGo HP shiftkit, Earl’s 19 row transmission cooler, FMS 3.73 gears, FMS aluminum driveshaft.
Wheels and Tires: 17” x 9” Replica Cobra R, 555 Nitto Extreme 255/40ZR17 rear & 235/45ZR17 front.
Brakes: Hawk HPS pads, Front 73mm calipers from 1991 Lincoln Mark VII, Sn95 MC w/3-2 port conversion & Russell SS hoses.
Chassis: FMS Subframe connectors, FMS upper control arms, MM lower control arms, Energy Suspension engine, transmission and front sway bar mounts.
