  • SN95 4.6L Mustang Tech
what to set fuel pressure at?
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Oct 12, 2009
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 12, 2009
  • Oct 12, 2009
what psi do i set my fuel pressure regulator to? isnt stock like 44psi?....
:SNSign:
trinity_gt
3,125
81
99
Canada
Oct 12, 2009
  • Oct 12, 2009
:SNSign:
The injectors are designed to operate across a nominal pressure drop of ~39-psi. At idle, if your engine is pulling say 18-inHg of vacuum so the idle fuel pressure should be set to about 34- or 35-psi or so. With the engine off, the pressure should rise to ~39psi.
98COBRA281
1,348
30
59
Oct 12, 2009
  • Oct 12, 2009
so with the engine off, and the key on, i should set it at 39psi?
trinity_gt
3,125
81
99
Canada
Oct 13, 2009
  • Oct 13, 2009
Yes.
98blackstallion
602
mtn home arkansas
Oct 13, 2009
  • Oct 13, 2009
is that with the vacuum line on or off?
trinity_gt
3,125
81
99
Canada
Oct 13, 2009
  • Oct 13, 2009
If the engine's not running, it doesn't make a difference. If the FP is to be set with the engine running, it can be done one of two ways:
1) Disconnect the vacuum line and expose the FPR to atmosphere. Set the FP to 39psi. Re-connect vacuum line.
2) Leave vacuum line connected and use vacuum or MAP gauge to determine manifold pressure at idle. If you know the inHg (inches of mercury) pulled at idle, you can roughly determine manifold pressure with:
Code:
MAP ~= (29.92-Vac)*0.491154
So if you're pulling 18inHg on a vacuum gauge, there'd be ~(29.92-18)*0.491154 or ~5.86psia in the intake manifold. Subtract this number from 39 to get the value you want to set the FP to (in this case, 39-5.86=33.1psi).
It's probably easier just to pull the vacuum line and set it to 39psi. :|
98COBRA281
1,348
30
59
Oct 13, 2009
  • Oct 13, 2009
how do you like you edelbrock intake? your the only other person that i have seen that has one.......
98COBRA281
1,348
30
59
Oct 14, 2009
  • Oct 14, 2009
i dont know if 39psi is enought?
i set it at 39 with the vac line off, and is breaking up really bad under acceleration with load, and it has terrible throttle responce, i dont know if it matters, but the car does have a walbro 255 pump, 24lb injectors, and was dyno tuned on the stock fuel pressure setting.......
trinity_gt
3,125
81
99
Canada
Oct 15, 2009
  • Oct 15, 2009
Can you leave the gauge connected and drive around a bit (carefully) with it to see what the FP is doing under other driving conditions? Are they FRPP injectors? And, silly question, but you're setting it to 39-psig, not 39-psia, right?
98COBRA281
1,348
30
59
Oct 15, 2009
#10
  • Oct 15, 2009
  • #10
i am leaving the gauge on all the time, they are denso injectors, and i have a autometer gauge that i set it to 39.......
trinity_gt
3,125
81
99
Canada
Oct 15, 2009
#11
  • Oct 15, 2009
  • #11
So what does the gauge show during driving, especially when the car is acting up?
What does it read at idle? At WOT? At part-throttle?
98COBRA281
1,348
30
59
Oct 15, 2009
#12
  • Oct 15, 2009
  • #12
i cant see it while driving, it mounted to the FPR under the hood, but at idle i want to say it dropes to about 30ish and when i rev it it never goes back up to 39, it bobbles aroung 35ish or less..............
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
