what tranny fluid?
In my old T5 I used just ford ATF. I always hear of people having problems shifting when they switched to synthetic. In my TKO however, all I run is GM synchromesh, which is what TTC/Tremec recommends. If you use anything but that, they will void any warrenty on the trans. EVERY time I called about a problem with my TKO the FIRST question out of everyone's mouth was "what tranny fluid do you use?"
Im using Red Line in mine as well, Been through 2 tranny fluid changes w/ it so far using Red Line.
how often does everyone here change there tranny fluid or how often is it recomended :shrug:
