What would be better??
What ever you do, avoid putting the air filter pickup inside the engine compartment. The disturbance from the fan makes airflow through the filter uneven & upsets the MAF readings. Some CAI kits have the same problem, hence the need to "clock the MAF" or roatate the MAF housing to find a spot with undisturbed airflow.
yes i agree... the only reason i noticed that throttle performance / overall smoothness was better was because when i installed the cai, it moved my filter into the fender. don't buy an expensive cai for any real gains.
ok, so both would give me the same gains?
the densecharger, i believe goes in the fenderwell, and I was going to cut out a PVC pipe leading into the fenderwell to place the FIPK on. i was just asking cause if i go the FIPK route, i'll be spending close to $100 more and if it's not worth it, then why bother.
