what would cause...clutch cable?
  • Thread starter Thread starter wshI_hd_1
  • Start date Start date Aug 11, 2004
W
wshI_hd_1
94
paulding, ga.
Aug 11, 2004
  • Aug 11, 2004
Well heres the promblem , i got an FFPR clutch quadrant and adjustable cable(no firewall adjuster). Neway, when i first get in the car its stiff and releases right off the floor, but after driving it a few minutes it loosens up and releases where its supposed to. But, today at school, i get in my car, put the clutch to floor to start it and *pop*, the clutch cable pops off the quadrant, its tight down on the release fork but loose up top, and the plastic peice that goes on the firewall , if held about an half inch from the firewall, keeps pressure on the cable enough to drive, but when put where its supposed to, the cable pops off and i cant tighten it...so do i need an firewall adjuster or is there summin im doin wrong?
THANKS
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 11, 2004
  • Aug 11, 2004
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
I have the same setup, the only additional step was to put a sheetmetal screw through the eye in the firewall mount. You will need to drill a hole using the eye as a guide, then install the screw.
When properly installed, there is preload on the cable so that it does not come off the quadrant.
The adjustment is simple, you hold the cable so that it doesn't turn (visegrips) and tighten up on the domed nut that is riding against the clutch fork. Tighten until you have taken all the slack out of the cable and tighten another inch more.
I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. If I shift only when the pedal hits the floor, there are several milliseconds that the clutch disk is not being driven by the engine or transmission. In theory, this lets the disk slow down some and makes less work for the synchronizers – keep in mind that this is a theory, but it seems reasonable. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate
Ourobos
260
Aug 11, 2004
  • Aug 11, 2004
Well said..
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Drivetrain Time to pull and lube the clutch cable
  • LX Dave
  • Dec 21, 2024
2K
Fox 5.0 Mustang Tech Jan 7, 2025
limp
