  • SN95 4.6L Mustang Tech
What would you do?
  • Thread starter Thread starter fromadig91
  • Start date Start date Jul 27, 2008
F
fromadig91
95
  • Jul 27, 2008
I am interested in getting more performance out of my car (NO WAY!). I perfer drag above anything else. Basically what would be an ideal set up to get the most out of my car without having to build up the engine.....I have an 04 GT
Currently I have a tuner and will be putting some 4.10 gears in the rear end, what else would you guys suggest if this was your car? The KB 2.1 should be coming in a few months but is there anything I need to do to prepare my car for it?
Basically what is going to give me the most bang for my buck
Open to any suggestions
Throttle Body?
Full Exhaust?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 27, 2008
  • Jul 27, 2008
If you are serious about the Kenne Bell then look at a 70 to 75mm throttle body. They offer them as an add on to their kit if you just want wait and gert it all at once. If you don't have any exhaust upgrades and depending you your cars use you can go with a mid pipe with high flow cats or an off road pipe. Depending on your budget you can go with Bassani on the high end or Mac if you are on a budget. I have the Mac Prochamber on my car.
The blower will give you the most bang in your stock form. If you upgrade anything else you will need to look at the internals of the engine. Once you get above 400-425 HP the stock parts tend to give up.
F
fromadig91
95
  • Jul 27, 2008
Thats what I was thinkin for the engine, I read in a few places once you push past like 475 you start having problems, so i figuerd the KB at 9 or 10 PSI would be a nice upgrade without exceeding the limits
Also I was wondering if anyone knows stock size throttle bodys on the 04 Gt's
RedDaemon
3,470
9
108
Atlanta, GA
Jul 27, 2008
  • Jul 27, 2008
if you want drag. all that power dont mean **** if you cant hook up.
get suspension and your rear end built and throw in some gears
great place for suspension: http://www.maximummotorsports.com/
BigDave06
39
Felton, DE
Jul 27, 2008
  • Jul 27, 2008
Reaching the limits of how much power I am comfortable making on stock internals I found myself asking the same question and I plan on doing some suspension mods they seem to make a very big difference, as well as weight reduction. I weighed in at 3350 with me in it last time I checked.
G
GettinThere
553
Central Texas
Jul 27, 2008
  • Jul 27, 2008
65mm
BannonJr
215
St.Lazare Quebec
Jul 29, 2008
  • Jul 29, 2008
some suspension work can knock down your et's..control arms, shocks...etc...
But maybe, more importantly, if you're going to be dragging, you'll end up with slicks, then, possibly a chattered diff...or axles...so take a peek at beefing up your rear-end...
flstang65
1,484
135
94
SE Georgia
Jul 29, 2008
  • Jul 29, 2008
Suspension! K member, control arms, c/c plates, coil overs front and rear, rear upper and lower control arms, sub frame connectors, bigger rear sway bar, no sway bar in the front. gears, rear diff girdle, weld the the axle tubes to the 3rd member, torque boxes, and some sort of roll bar/cage. Just my .02. Good luck with the build!
Superhereaux
chicks make me feel inadequate
538
South Texas
Jul 29, 2008
  • Jul 29, 2008
I'd skip the gears entirely if you're going with a 2.1KB but that's just my opinion, the money is better spent elsewhere.
I'd focus on a nice quality exhaust (Bassani, SLP, Magnaflow, etc.) and suspension. oh, and sub-frame connectors are pretty much a must on these cars so look into that if you haven't already
What Movie Would You Make?
  • Noobz347
  • Oct 9, 2026
  • Off-Topic Hangout
Off-Topic Hangout Oct 14, 2026
DadLife0724
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Hit something exiting
  • Creomod
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
General karthief
