  • SN95 4.6L Mustang Tech
What year engine will work???
  • Thread starter Thread starter SyberSaint
  • Start date Start date Dec 20, 2006
SyberSaint
252
San Antonio, Texas
Dec 20, 2006
  • Dec 20, 2006
Hello Again Guys,
A few posts back, under "Blown Engine???", I explained how I may need a new engine in my early build 2001 gt. Now I am asking, when I find one, what years will be a DIRECT drop in. Is there anything that I have to be concerned with, or look out for when getting one. In other words, will any year up to 2004 work????
Thanks again,
Dale in San Antonio
cobra killer
2,325
dallas ga
Dec 20, 2006
  • Dec 20, 2006
99-04 are direct drop ins. The only difference would be if your supercharged. In that case 99 -00 have larger bolts in the timing cover than 01-04. If its N/A,any thing from 99-04 will bolt right up.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 20, 2006
  • Dec 20, 2006
also 99-mid 01 used 8 bolt flywheel (01-04 went back to 6 bolt)
so if the engine your buying comes with a 5 speed flywheel you should be fine
sgarlic
3,085
Dec 20, 2006
  • Dec 20, 2006
03/04 have 21# injectors, while the earlier models had 19#. I would think since so many tuners are always pushing "calibrate the MAF for the injectors!" .. that perhaps if you use the 21's, you'd need to change a setting or 2 in the PCM.
cobra killer
2,325
dallas ga
Dec 20, 2006
  • Dec 20, 2006
Actually only 99-00 use an 8 bolt flywheel,but I did forget about that part.
the98stang
2,408
Clovis, CA
Dec 20, 2006
  • Dec 20, 2006
Your not thinking about dropping in a STOCK engine are you?
Just spend the extra cash and buy a forged motor from VT or MPH. You can use the heads from your old engine.
jstreet0204
939
Winston Salem, NC
Dec 20, 2006
  • Dec 20, 2006
If you read his other post, it is a 2001. He has had the car since it was new, and never did any mods to the engine. Unless he has suddenly changed his mind, a forged motor is a waste, and a stock replacement is perfectly fine for his daily driver.
R
Roger_4.6_96
1,209
Reno,NV
Dec 20, 2006
  • Dec 20, 2006
Stick cobra engine in there.
04YELLOWGT
1,135
Indiana
Dec 20, 2006
  • Dec 20, 2006
+1 on Cobra engine. What about the new Shelby engine... only $15,995.99!!!!
urban96
3,464
Syracuse, NY
Dec 20, 2006
#10
  • Dec 20, 2006
  • #10
i thought they changed it over with the transmission. good info
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
