Whats everybodys comments/experience on Lucas oil additive???
Black1987Stang
1,422
Jersey Shore
Just wondering what everybody has to say about Lucas....Personally I dont like to add stuff to my engine oil since the oils are made to do whats its made for and if u add something else it might not be able to do its job properly, just my thoughts.....and Im sure someone will post up the article from the Bobistheoilguy.com site when he did the test with Lucas in a rotating gear assembly.....whats everybodys thoughts about Lucas, ever use it in ur engine oil, tranny oil, rear end? comments, complaints, etc.
The oils I use are already pretty highly rated at Bob's site. Amsoil in my 2 strokes, Pennzoil Platinum in my Cobalt and F-150 and Pennzoil 10-30 in everything else including the 5.0. I have had no oil related issues with anything, ever. I see no reason to put any additives in any high quality oil.
i tried it for awhile then stopped cause i noticed no real difference but i use castrol gtx in the 5.0 and an fl1a filter i did use there gear fluid for the 8.8 in the rear and i use lucas top end lubricant regularly
It`s well marketed garbage,in the same category as Slick 50,Dura Lube and many others.
I`ve read of other sources saying it causes oil to foam not just on the bitog site.
