housing end flange with a vertical bolt pattern ... effectively takes out any simple bolt-on qualities of the '03 version.
Unless you were already narrowing the housing, right? Or would it be extra work above and beyond to rotate the housing ends?
I think thats a front rotor isn't it ?
found 'em, DBA rotors (Disc Brakes Australia) makes them and they are difnitely vented, in fact they make 2 versions; the 4000 series and the 4000XS series. i found them here
DBA Rotors, DBA Brakes
these are also probably the same rotors that RRS uses on their rear disc brake kit, i would bet.
Unless I'm just overlooking it, I don't see anything that definitively states or shows the rotors as being for the rear.
The one in the photo appears to be for the front since the sides of the hat taper inward toward the wheel mounting surface. A rear disc with an internal set of drum shoes for the parking brake would have a hat with parallel sides.
wow this thread blew up since the last i've seen it!
I have a stock 67 mustang 9" housing and I plan on running aftermarket 31 spline axles. I have slotted and cross drilled rotors on the front so i'd like to have the same on the rear...but dang those rotors are expensive!! So if I wanted to mount the crown vic rear brakes what are the best years to get? Are they bolt on or do they require any fabwork or welding?
quick Google search found it - I looked up "crown victoria vented rotor"
Power Stop Rear Cross Drilled Rotor 1996 - 1997 FORD CROWN VICTORIA V8 4.6 Liter (281) CNG F/I Part#: AR8152DPR
