Whats the most nitrous i can run on my new stoker?
Xtreme Limits
375
Hudson, Florida
When i get my dart block and, on my 418w Stroker, bored .030 over, arp studed mains and main girdle , Probe pistons 10.2:1, Manley H-beam rods, 4340 hawks crank 4.1" stroke, ProTopline/RHS 215cc/56cc/2.08-1.60 valves, Comp cams XFI 236HR-14/.579lift/286-300dur., roller lifters, Comp cams 1.6 aluminum roller rockers, 28oz balncer, C&L 80mm maf, FMS 42lb injectors, 75mm TB, Victor 5.8l efi intake, ProComp 351w efi distributor, Msd digital 6 with HVC coil, looking for 500+Hp&500+lb of torque,
How much nitrous can i run on the dart block with my motor on race gas.... im going to run 200sho max with my sportsmen block, on the dart block can i spray a 400-500shot hp of nitrous?
Should be no trouble to go with a huge hit like that. Remember when you run lots of juice you want more ring gap so that as the temp increases in the cylinder you have allowed room for the rings to expand. Your engine will no doubt use oil but it is what you have to do if you are going to run a huge hit. Talk to Bluevenom867. He is a nitrous junkie and also runs 351w based strokers. He will be able to help you out.
