  • 1994 - 1995 Specific Tech
What's up with my compression!?!?!?!?!!
  • Thread starter Thread starter 95Vert
  • Start date Start date Apr 27, 2006
95Vert
1,785
North Mexico (deep south Texas)
Apr 27, 2006
  • Apr 27, 2006
Ok, so I can hear my rockers. I freak out for a minute and then calm down. I take it to a local shop and the guy tells me that it's my oil pressure. Gives me a 20min speech about how the cam bearings and rings all crap must be worn out and I NEED to rebuild my engine. I freaked out at first and went home. I called up a couple of other friends and one told me to remove the VC and start the car to see if oil was traveling up to the rockers. I only did it on the passenger side, and it looked fine. So today, I take it to another shop for a compression test and I get this C1=75, C4=85, C5=75, and C6=75 I wasn't sure what it was supposed to be at but I knew those numbers were bad. The guy also checked my oil pressure and I was at 50lbs at idle. WTF could cause these compression numbers. My plugs were free of oil, my car isn't smoking, I have no power loss, and I'm clueless how my compression could be this low. Any advice?
94-302-vert
1,947
NE CT
Apr 28, 2006
  • Apr 28, 2006
OK, here are my thoughts:
I am not sure how much an ecam affects the compression, but I know cams typically can give lower values.
What did the other 4 cylinders test at?
Is this the stock bottom end? How many miles?
Swarzkopf
973
Pittsburgh
Apr 28, 2006
  • Apr 28, 2006
They can? How? The valve still closes, compression shouldn't change...right?
As to the original post...
You need to check your compression yourself. **** what the shop says. Buy a haynes manual for $15, buy a compression gauge for $30, and do the test.
If those numbers are accurate, your motor IS toast.
Test all the cylinders. The lowest test cylinder should be 75% of the best cylinder.
Generally, I'm under the impression that anything over 120 is "okay". Stock 5.0s tend to test between 145-155 from what I recall..I believe that my own car's lowest cylinder was 135 when I last tested it a few months back.
Good luck.
bill302
2,131
alabama,gadsden
Apr 28, 2006
  • Apr 28, 2006
click on link info. on compression testing and do your own test as Swarzkopf stated above. wal-mart sells the compression test guage and hose for about $20...
http://www.pumaracing.co.uk/comp.htm
94-302-vert
1,947
NE CT
Apr 28, 2006
  • Apr 28, 2006
Actual compression only starts once the valves are both closed. If the intake valve stays open too long to better fill the cylinder then you have less gass to compress and therefore lower numbers.
Now it is also possible that the gagge itself was horrible and hence the need to know what the other 4 cylinders were. How was this tested? Was the engine turned by hand (single compression stroke) or allowed to spin on the starter until the pressure maxed on the gage (multiple strokes)? Remember the gauge adds to the overall volume of the cylinder by a very high %.
Swarzkopf
973
Pittsburgh
Apr 28, 2006
  • Apr 28, 2006
I've never heard this before...for all I know you could very well be right, but this just doesn't make sense to me.
Unless one of the valves is open when the piston begins in compression stroke, the compression reading should not change whatsoever. Is it common for an aftermarket cam profile to keep the intake valve open as the piston begins the compression stroke?
Otherwise, wouldn't the valve staying open HELP in compression as the intake stroke draws more air into the cylinder?
bill302
2,131
alabama,gadsden
Apr 28, 2006
  • Apr 28, 2006
could your cam timing be off a tooth or more....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 28, 2006
  • Apr 28, 2006
Very good point
Duration can bleed off some squeeze
Like you ... don't know if that is an issue with the e cam
Those values do look low.
Maybe the valves are too tight
Shims/different length pr's ... gotta love the peds
Grady
95Vert
1,785
Apr 28, 2006
  • Apr 28, 2006
It was a multiple stroke test. He only did 2 on each side. The pressure would jump from 30 to 75 and then stay there.
Need more info on what you're talking about Grady, please.
95Vert
1,785
Apr 28, 2006
#10
  • Apr 28, 2006
  • #10
Oh, and my lower end if off an 98 Mountaineer(Explorer) and it was 67k miles when I got it. Don't know if that matters. Our compression ration should be at 8.5:1 right?
94-302-vert
1,947
NE CT
Apr 28, 2006
#11
  • Apr 28, 2006
  • #11
I think you are fine.
I would get a compression tester and test all 8 cylinders yourself.
Are the rockers adjusted properly?
95Vert
1,785
Apr 30, 2006
#12
  • Apr 30, 2006
  • #12
Not sure. I just tightened them til they were snug. I'm going to install new lifters with a friend, and he's going to check all of that. And what makes you think my car is fine?
95snoozer
2,572
RCR
Apr 30, 2006
#13
  • Apr 30, 2006
  • #13
if your rockers are a lil too tight, they could be opening the valves enough to bleed compression off
95Vert
1,785
Apr 30, 2006
#14
  • Apr 30, 2006
  • #14
That could be the reason why this is happening. I mean, it's weird that my compression is so low when my car feels strong and is not smoking or burning or leaking oil. I may be leaving power on the table, but it still doesn't feel "slow".
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
