- Nov 10, 2005
- 38
- 0
- 0
ok I went and had the wheel hub assembly replaced. All is fine right? Wrong.. on the way home I hear a thumping noise on the same wheel that was worked on. So I take it back and the guy tries to tell me that it's a bad tire, then when I didn't buy that he said it was the wrong lugs.. I took it to a couple other shops and each one said that it looks like a defective bearing because the wheel still has some play in it. Also the faster I drive the louder it gets. I asked the mechanic if he used a new nut on the bearing and he said no he reused the old one. I read that you MUST use a new one. They are replacing the wheel hub assembly again this weekend. Does it sound like a defective part to you guys?
