when i turn off the engine....
  • Thread starter Thread starter Stang_1973
  • Start date Start date Dec 30, 2008
Stang_1973
565
9
38
San Antonio, Tx.
Dec 30, 2008
  • Dec 30, 2008
Strange thing happens when i turn off the engine.
For some reason when i turn the key back to turn off, the engine seems to shut off but stutters a bit and dies after ive already turned the key back. Its weird and i dont think it should be doing that.
Why does it do this? is it bad timing? running too rich and theres still fuel in the cylinder?
A
Arron Johnson
Banned
Dec 30, 2008
31
Sonoma, CA.
Dec 30, 2008
  • Dec 30, 2008
What you have going on sounds like what's called "engine run-on". What is happening is a couple of the cylinders are continuing to light after you've turned the key off. This can be caused by a number of things:
1) Crappy gas, or gas with too low of an octane rating for the amount of compression you have so it "diesels" after you've shut it off.
2) Carbon build-up in the combustion chambers and/or on the tops of the pistons. When these carbon deposits get hot, they glow cherry red and can continue to light a cylinder or two after the key is turned off.
3) A poorly running and/or adjusted engine in which the throttle plates on the carb are opened too far in an attempt to keep the engine running at an idle. When you turn the key off, the idle position is too far open so fuel continues to flow into the engine and hot spots in the cylinders will continue to light a few of them.
Before EFI really became popular, cars of the 80's and 90's had idle stop solenoids which completely closed the throttle plates to eliminate this same problem.
Timing has nothing to do with it because they key is off. No key = no spark. No spark = no ignition or timing.
Usually when an engine does this it will rev up at the very last minute (sometimes even backwards), which will push out a foul smelling cloud of unburned gas. When you go to fire it back up, it "can" be a little more difficult because of the reverse running of the engine.
My first guess would be to take a peek at the carb to make sure it is adjusted correctly. if it is, then try putting a little better fuel in it and try a pint of Berryman's B-12 Chemtool in the tank to help clean-out any carbon build up.
A quick way to remecy this if you can't find the problem is to simply shut the key off while it is still in gear. The load of the tranny will help stop the engine from free spinning as easily and it should shut right off.
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Dec 30, 2008
  • Dec 30, 2008
all hail the new member!! lol, on a side note, great to have ya with us arron, its always nice to have another knowledgeable fella!
rbohm
6,698
550
204
tucson,az
Dec 31, 2008
  • Dec 31, 2008
well said arron. usually the problem is a hot spot in a few cylinders, and enough fuel flowing from the carb to provide an ignitable fuel mixture in those cylinders. it is usually carbon build up or spark plugs that are running a bit too hot, combined with throttle blades being open too far.
Stang_1973
565
9
38
San Antonio, Tx.
Dec 31, 2008
  • Dec 31, 2008
Thanks for all the help aaron. your a wiz.
Ill look into this, Its really annoying.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Dec 31, 2008
  • Dec 31, 2008
Aaron's #3 is the most common reason for engine run-on (at least in my experience)
Stang_1973
565
9
38
San Antonio, Tx.
Feb 13, 2009
  • Feb 13, 2009
ok so i believe its probably #3. I found an awesome video on youtube by boxwrench channel to adjust holley carbs. I got my self a diagnostic tach so im gonna be checking my idleing and such.
Thanks guys for all the help.
for anyone else interested in the vids click here.
YouTube - BoxWrench's Channel
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
