When to install an aftermarket K member
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,467
2,902
173
Florida
Do the stock K members wear out or would a new aftermarket K member be worth the cost for a daily driver?? Engine is coming out of my 83 convertible tomorrow and if there is a time to replace it, now would be it.... Give me some reasons to or NOT to waste money on it...
Thanks to all on here
The stock K-member does not wear out, but it can rust out. The factory K-member is generally stronger than all but a few of the aftermarket tubular K-members. In fact, putting a tubular on a street car can be a bit of a hazard, since most of them are designed for drag racing, and aren't really up to the daily challenges of rough roads, pot holes, curbs, etc, that can cause them to break. There are a couple of possible advantages to a tubular K-member. The primary is weight, and on a drag car, every ounce counts. It's actually not that much lighter than a stock K-member. The second is control arm angle for better handling. The biggest advantage to a tubular is that it doesn't become a collection tray for 8mm sockets, and makes working on things like starters and exhaust easier. Generally a tubular K-member is not a recommended mod for a street car.
Kurt
  • Useful
Reactions: 7991LXnSHO and limp
Thanks Kurt,
Rust is not a problem with this car, it is basically rust free ( lucky for once LOL) My concern was if the K member weakens over time due to years of flexing or metal fatigue... Any thoughts on lower control arms?
As someone who just installed an aftermarket k-member and tubular arms, I’d say that unless you plan on going to town on this car with major mods, leave it alone. The stock one is fine. The stock one is strong.
there are benefits to them, but generally for a street cruiser type car...leave the stock one
Thanks Kurt,
No chance of flexing. Those factory K-members are rolled steel, and unless the car has been in a collision, it's going to be strong. Control arms all depends on what you want to do with the car. The stock ones don't bend unless they are in a collision, and last forever. So there is nothing wrong with putting new bushings in, and new ball joints.
Kurt
Reactions: limp
Did you plan on going to town on yours? Isn’t your car gonna be a street cruiser type car?
if I could go back in time, I would have just done a set of springs and good struts and called it a day. Unfortunately it snowballed. Now I have a lot of fancy parts to cruise down to the local coffee shop with.
With that said. I won’t be taking any of them off anytime soon
  • Haha
Reactions: Habu135 and limp
after seeing a few different K members installed I have to agree with the above statements... I have a UPR K member in my car and it would be great for a drag car, but I wish I would have used the MM K member as it is much more substantial. In my case I did not have a choice and needed the clearance a tubular K member allows.
Reactions: General karthief
Based on the pictures I have seen, the BMR, using the stock springs, would have been my pick... Again based on the pictures it looked pretty beefy to me..
My knowledge of Foxbody cars is "ZERO" so as I delve into this project websites like this are priceless to me.....
I started this post as I am at a good place IF I was to do a new K member its now... I have seen so MANY after market K members produced for Fox bodies I thought there might be a weak point in the stock K members.... Glad to know that the stock one will work fine for me.....
most of the K-members are drag orientated. The MM is road-course based. Even Jack Hidley has stated the stock one is stronger still.
they still can be bent. I have one that’s bent. (Which is why I bought the MM unit.)
Can a person still get a NEW stock K member????
Perhaps not, at least, I'm not aware of one but...
There's a metric chit-ton of them in the junkyards.
Off-Topic: Your screen name is about to change. I am open to your suggestions as to what it will be. This will occur today.
Refer to the Terms of Service for more info and Private Message me with any questions.
  • Hell Yeah!
