  • 1994 - 1995 Specific Tech
when to replace harmonic balancer?
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Jul 25, 2005
1994Vib.RedGT
585
Denver, CO
Jul 25, 2005
  • Jul 25, 2005
Ok, my harmonic balancer has a little bit of rubber slipping out of it, and I asked a mechanic and he said you dont need to do it right now, but it wont be too long, so when am I going to need to replace this mother??
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 25, 2005
  • Jul 25, 2005
I'd vote for immediately. Rubber coming out means it's already slipped, and is more than likely off balance. A couple hundred dollars now is cheap insurance, versus a new shortblock IMO.
BULLITTSTANG95
97
Oklahoma City
Jul 25, 2005
  • Jul 25, 2005
i am with him ...replace it now cause it could cause serious damage in the near future if not. you can go with a one piece for couple hundred or you can order a stock one from summit for around $75
Blk05Retro
99
Katy, TX
Jul 25, 2005
  • Jul 25, 2005
It's to late when your engine gets flung out of the engine bay. If you got rubber spitting out, its already damaged.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jul 25, 2005
  • Jul 25, 2005
Question: When?
Answer: Now!
Totally agreed.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jul 25, 2005
  • Jul 25, 2005
ASAP if don't need to wait then why wait....
9
95cobra50
167
  • Jul 25, 2005
mine spun in two then i replaced it
tim95gt
44
Kernersville, NC
Jul 25, 2005
  • Jul 25, 2005
like they said do it soon, mine started to make my entire engine, steering column and everything shake
rude_life
372
  • Jul 25, 2005
You know what, come to think of it, I get a vibration at high RPM's but a NASTY vibration at high speeds, I mean it rattles so bad it hurts my hand when I have it still on the shift knob. This all started immediatly after installing the new gears so Im figuring driveshaft. But if Im in neutral, say at a stop sign or just in my driveway, and I rev the engine up, as it idles back down..Just as the idle rolls down to exactly 1,000-1,200 RPM, I get a pretty good vibration all throughout the vehicle. It actually shakes my car.
May I possibly be in need of a new HB?
Thanks...
Kris
HISSIN50
34
129
Jul 25, 2005
#10
  • Jul 25, 2005
  • #10
Kris, vibes while stationary are motor related most of the time.
Vibes while rolling can be either (so the usual check is to see if the vibes can be replicated while stationary).
With your stationary vibes, can you replicate the vibes when goosing the throttle from idle up to the vibration spot (1000-1200 RPM)?
There are a lot of engine and engine management dynamics at work when the idle is coming down - if you can make the vibration happen another way, it helps rule out an engine management burp.
Good luck.
rustang94
281
Milwaukee WI.
Jul 25, 2005
#11
  • Jul 25, 2005
  • #11
What is the best aftermarket harmonic balancer for are cars?
droptopford 5 0
427
Jul 25, 2005
#12
  • Jul 25, 2005
  • #12
just got done replacing mine not more than 10 minutes ago... i saw the rubber piece slipping out about a half of an inch so i went and did the deed... just a note, make sure you buy one that doesnt need grinding on the water pump... my ford racing balancer which was labeled as a stock replacement needed grinding on the bottom of the water pump. might as well replace the oil seal while you're down there, just remember to put some gasket sealer on the keyway of the crankshaft to prevent oil leaks there, good luck!
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 25, 2005
#13
  • Jul 25, 2005
  • #13
Nnnnoooowwwwwwwww
rustang94
281
Milwaukee WI.
Jul 25, 2005
#14
  • Jul 25, 2005
  • #14
ttt
stanglover2358
#15
  • Jul 25, 2005
  • #15
I Broke my harmonic balancer in half last summer. I replaced it with a professional products harmonic balancer, and I have been running a powerdyne supercharger for the last 5 months and I havent had any problems. There are other mods as well
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
