When to replace parts for maintenance...
  • Thread starter Thread starter BLADDER92FOX
  • Start date Start date Aug 21, 2005
BLADDER92FOX
153
Miami
Aug 21, 2005
  • Aug 21, 2005
I have a question regarding on within how many miles do you replace the following parts:
Pcv valve,breather screen,fuel filter,spark plugs,cap and rotor,and spark plug wires.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 21, 2005
  • Aug 21, 2005
Those parts should be good for a 50k mile maintenance interval - I'd add in the O2 sensors as well.
bubba-dough
1,044
Indiana
Aug 21, 2005
  • Aug 21, 2005
I agree. Or you could just do it once a year, that makes it easy to remember.
Maintenance and engine life go hand in hand. I am anal about my maintenance, I really over do it. But with the money,time and headache put in this thing, I don't want to chance it
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 21, 2005
  • Aug 21, 2005
There's absolutely no reason to replace all that stuff once a year....unless of course you just want to.
bcmbcmbcm
20+ Year Stangneter
Jan 29, 2003
455
  • Aug 21, 2005
Although you didn't ask about it I replace ALL rubber parts (belts and hoses) every 5 years. My car sees little mileage during that time so I feel ok stretching it, but I know it is all new. I don't want to mess with replacing one hose at a time.
M
mackey
1,284
Beverly, Massachusetts
Aug 21, 2005
  • Aug 21, 2005
Plugs i do every year. Belt gets a new one every year.
87MustangGT5.0
153
Maryland
Aug 21, 2005
  • Aug 21, 2005
Do you guys ever replace the EGR valve during the whole life of the car?
BLADDER92FOX
153
Miami
Aug 21, 2005
  • Aug 21, 2005
My pcv valve,fuel filter,spark plugs,cap and rotor,and spark plug wires were all changed over a year ago. My next oil change is in 2 weeks so i was wondering if i should also replace my plugs and a few other things like the fuel filter.
T
TheUser
1,859
Springfield, MO
Aug 21, 2005
  • Aug 21, 2005
The only way I could see changing anything would hurt the car is if you break something...replacing the parts won't hurt anything, just might not be necessary.
Autolite plugs are like $1.29 at autozone, so for $10, if you want to do the work and it makes you feel better, I say do it. The fuel filter is pretty cheap and easy too, but again, might not be necessary at this point.
I can't see doing the pcv valve/screen since it was only done a year ago and it's a little more involved than plugs.
Basically, I might replace the cheap stuff, but unless the more expensive or harder-to-change stuff fails (O2's, plug wires, cap/rotor), I'd leave it on for another year or two.
I'm no expert - these are just MY opinions
BLADDER92FOX
153
Miami
Aug 21, 2005
#10
  • Aug 21, 2005
  • #10
Sounds good to me,my car is running very strong and has been since i've doem all that stuff over a year ago.I guess i'll change things a sthey break or if i notice a change in performance. I did forget to run fuel injector cleaner my last oil change,so this time i'll buy some when i do the oil change.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Aug 21, 2005
#11
  • Aug 21, 2005
  • #11
Goin by age or milege is just a guidline so you can "plan" for expences. The manufacturers figure the age where a certian part begins to fail, and recomend replacment then as prevenative maintence.
Some parts because they may still be good, but not optimal should be replaced more often especailly in a high performance engine.
Some simple inexpensive parts can cause much greater problems if they go wrong. A clogged PCV system can cause oil leaks and can also cause an engine to blow oil up into the intake. A clogged fuel filter causes greater resistance to a fuel pump and can burn out the pump. Bad plugs/cap/rotor/coil/wires can burn out the cats. All of these can reduce the engine's output as well.
If you replace a prevenative maintence part or do a tuneup, and can feel a noticable difference then you were overdue.
vristang
4,933
101
124
Seattle
Aug 21, 2005
#12
  • Aug 21, 2005
  • #12
Don't know what the scheduled intervals are but I know most manuals have them in the first chapter or two.
Belts were mentioned.
I have never replaced a belt due to failure or even significant wear. Unless you count when the air pump seized. In my opinion the belt is a easy visual inspection. If you have custom accessory brackets your belt should be fine for several years. I change the accessory setup (which requires a new belt) more often than I need to replace the belt due to wear.
In my experience over the last 10yrs owning the GT...
I have supsected a coolant stat of failure, but never seen one fail.
I have seen a fuel filter go bad after sitting for 8-9mo. with the fuel lines un-hooked at the motor, but that has been my only fuel filter trouble. I still replace this fairly regularly though.
I have never seen a pcv fail. Every single one I have replaced was still fully functional when removed. Be sure to hold the pcv in the proper orientation when checking it.
I have not seen an egr failure or a iac failure either. They do need to be cleaned though.
I have yet to have a tps sensor go bad. Each time I suspected the tps and replaced it, the problem turned out to be elsewhere.
As a result of all of these experiences I now have many replacement parts that turned out to still be good.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
