when to up grade axles
noslow1986
274
oswego Il
i got some 4:10 gears when do i need to up grade axles. i dont have much done but with 4:10 i dont want to break a axle should i go ahead and spend the money while they have my rear end apart or what til a later day
Depends on where you want to end up. If you want to be in the 10's, 9's and mostly a track car, then you may was well do it now. if you are just going to be a quick street car then the stockers will be fine as long as you stay with street tires and not going with street/drag tires. The stickier you get the harder it is on the axles.
as of right now im using nittos street tire. just mostly street racing, maybe track here and there not much. i just dont want to break an axle at the track my car is an 86 and its 20 years old but im going to weld my torque boxes for sure
