Where does the ABS sensor harness end?
I know the rears go up under the seat and then plug in....If you roached the rears, a salvage yard will sell them for like 50.00 a pair....i had to replace em when i swapped gears...they suck !!!!
They send me like 12" of wire plus the sensor...i just cut and connected them in...
The fronts??? never had to deal with em....
NEEDA5.0 said:
Is it plug and play or do I have to cut and solder?
I don't know if the set-up is exaclty as the fronts, as I just cut off 8" or so and cut them in place..just used crimp connectors on mine...I know i had fronts as they had the bracket that goes to the strut on them....i said W.T.F.??? so your not alone there... :D
Well I broke the old ones and I already have the fronts so I might as well cut em both and give it a try. I'll get some shrink wrap today and solder em on. I'll let you know the results. I can't see why it wouldn't work.
