Where is a light dimmer wire for my NOS gauge LED light
poonstang16
29
I am going to install a NOS gauge this weekend in my 05 gt. It is an Autometer C2 series and has an internal blue LED. Specifically I would like the gauge light to turn on when the dashboard lights come on and to dim when I dim the dashboard lights but I do not know where to find the dashboard dimmer light wire. Any ideas?
Also anyone hook up this configuration before ( a gauge with an LED light)? I know there are adapters to make them dim better if you have stock incandescent bulbs but I figured if I use a dimmer from the instrument panel LEDs this should already be accounted for. Anyone experienced with this?
gauge
sorry to tell you but i went through this already, the dimmer runs on a negative lead so the dimmer will not work with the gauges. i ended up putting the power to one of the pink wires that run off the ignition. this powers the gauge when the key is on but will not dim.
