Where is the starter relay?
denialdave
223
North of Seattle
I assume it is in the fuse block under the hood, but I see four relays. Anybody know which one. I want to replace it on the chance it is bad.
iIam still trying to get car to start after putting in new starter, CPP switch (clutch shut off) and several electrical tests.
You're correct...the starter relay is located in the engine compartment fuse panel. Your owners manual should identify which one is the starter relay. Good luck!
