Where should I go next with my '04 GT?
  • Thread starter Thread starter Sonic04GT
  • Start date Start date Oct 28, 2010
First Prev 2 of 2
GDawg
1,469
Nevada
Oct 29, 2010
#21
  • Oct 29, 2010
  • #21
N8Dogg98 said:
Agreed. He also cuts back the intake valve to work with more aggressive intake centerlines which is awesome. Unfortunately for the OP this is too much if he's already having reservations about installing cams. I am trying desperately to have enough money by spring to buy a set of his ported stage 2 heads and 2P cams
I'm a little ignorant to this stuff but I am taking classes about it right now. So let me ask you... instead of the heads and cams you are buying, couldn't you go to 4v heads and cams or is there more expense involved? I'm researching doing different cams, valves, springs, pistons and rods but I'm just learning.
I started a blue print for my engine but can't do the inside measurements just yet but have stock specs.
N8Dogg98
3,872
238
184
MN
Oct 29, 2010
#22
  • Oct 29, 2010
  • #22
I probably could, but performance would suffer. 4V heads for example have larger combustion chambers so my C/R would actually drop if I kept my NPI short block stock and swapped to 4V heads. With the MHS stage 2 PI heads and 2P cams, the c/r should bump up to around 10.5:1 and with a tune I would likely exceed 300 RWHP with solid midrange torque and very little, if any, torque lost down low.
Keeping in mind that the heads, cams and a tune will run around $2200, I don't think I could make even close to the same power using 4V heads and a budget of only $2200.
BurningRubber
1,865
24
58
Oct 29, 2010
#23
  • Oct 29, 2010
  • #23
4v swap also entails a 4v intake, which also entails a 4v throttle body, linkage, sensors, etc. Also need a 4v timing cover, timing equipment, and so forth. They are good heads, but unless you're getting everything for a very good price, it can get very expensive.
Just a set of cams alone for a 4v are $1200.
N8Dogg98
3,872
238
184
MN
Oct 29, 2010
#24
  • Oct 29, 2010
  • #24
Exactly, and without touching the stock NPI short block, there is no way a N/A 4V swap would perform better than installing ported PI heads and a nice set of cams.
bjtheman1
#25
  • Nov 11, 2010
  • #25
Take it from me, save your money up and buy an S/C. I started with all the basic bolt-ons, spent around $2K or so on misc stuff. My car was still slow.
I finally got a Vortech V3 Kit Non-I/C and it's like I got a new car. Had it for almost 2 yrs now and love it!
navarro98gt
213
chicago, IL
Nov 11, 2010
#26
  • Nov 11, 2010
  • #26
This
K
keith.stangman
texas
Nov 16, 2010
#27
  • Nov 16, 2010
  • #27
i need ideas on my stocker 96 gt convertible 100% stock with some 44 flow masters i was thinking of doing a off road x pipe but lost after that
BurningRubber
1,865
24
58
Nov 16, 2010
#28
  • Nov 16, 2010
  • #28
Gears and a PI swap (99-04 heads, cams, and intake) plus a tune.
The X pipe is a good mod as well, but some people like the sound of an h-pipe with Flowmasters better. It's a personal preference.
Sonic04GT
844
West Palm Beach, FL
Nov 16, 2010
#29
  • Nov 16, 2010
  • #29
This was the difference between and O/R X with stock headers and an O/R H with longtubes. Both with a standard magnaflow catback. I like the H better.
YouTube - 2004 Mustang GT Magnaflow Exhaust
YouTube - 2004 Mustang GT Dyno Tuning
I really do want a blower but I'm starting to think it's just going to encourage me to beat on my car, and will take life out of it. Say what you will haha but it's my daily driver and I try to be very gentle with her, except for the occasional fun here and there.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Nov 17, 2010
#30
  • Nov 17, 2010
  • #30
navarro98gt said:
This
Dark04GT
758
62
59
NC
Nov 17, 2010
#31
  • Nov 17, 2010
  • #31
I agree with the sound choice as well.
I was in the same debate, boost vs. nitrous vs. staying NA. I figure you will beat your stang just as much as you always have, with every mod I have had, I have not beat on it more than before.
Despite the fact that the s/c or nitrous would give me more... I went with a set of hitech cams, I wanted a little more fun and I wanted the sound of a cammed stang. I'll add a s/c or nitrous to a future car once I am in a more comfortable position with a daily driver and a toy. But my goals may be different from yours. The s/c is by far the best way to add power if you want it.
Sonic04GT
844
West Palm Beach, FL
Nov 20, 2010
#32
  • Nov 20, 2010
  • #32
I believe I will end up going your route. Have you looked into any issues with adding a blower with that model cam? Just need to find a shop that will install and degree them for a reasonable price.
Dark04GT
758
62
59
NC
Nov 20, 2010
#33
  • Nov 20, 2010
  • #33
Hitech has blower cams as well. From everything I have seen it seems that NA cams will still give you gains with a blower. They may not be optimized but they will still net positive. Besides it will be a while till I can afford a second car... have to buy a house first.
fobra559
At least it's more erect and not floppy anymore.
Nov 1, 2007
721
Lindsay, CA
Nov 25, 2010
#34
  • Nov 25, 2010
  • #34
If you haven't already, I would start working on the suspension, LCA's, SFC's and struts and shocks are a great start before you plan on going FI.
Sonic04GT
844
West Palm Beach, FL
Nov 25, 2010
#35
  • Nov 25, 2010
  • #35
Good to know!
Already got em MM subframes, tokico blues, steeda sport springs, steeda cc plates. MM LCAs in the closet waiting to go on.
First Prev 2 of 2
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
