I'm converting a 5.0L roller cam block to carb to put in the 67. I'm going with a mechanical fuel pump but the current dowel pin is too short since it used an electrical fuel pump. I can't get the pin out of the 289 without damaging it so I'm going to need a new one. From what I've found, the engines with electrical fuel pumps used a 1.125" pin? and the ones without used a 1.325" pin? Where can I buy these individually?
Also, what is the best way to press fit them in without using an actual press?
Thanks
Thanks
