Where to put CD player ?
  • Thread starter Thread starter Myfirst67
  • Start date Start date May 7, 2004
Myfirst67
88
richmond, California
May 7, 2004
  • May 7, 2004
I know no one want to hack up there dash just to put in a CD player.So of course i want to put it in my glove box,but what i wanted to know is how do i make the bow for it? or is the a kit i can buy for it? Oh its going to be in a 67 coupe, any info will help
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
May 7, 2004
  • May 7, 2004
put it in the stock radio bezel. buy a used or repro one.
D
Demonic
40
  • May 7, 2004
what he said...
Just use one of them detachable faceplate ones. Just the other week I had a freinds car get broken into only to steal the faceplate. Apparently the guy used a flat screwdriver to pop out the key lock above the door handel and giggled the mechanism to unlock the door, got inside and stole the faceplate. Pretty lame, and the faceplate costs like 200$+ and now hes got some body damage where he bent the metal to pop out the door lock and messed up the paint around the area.
Had he of taken the faceplate off, the car wouldn't of gotten broken into.
Kinda makes me think about streamlineing my own car doors and useing a remote controlled electronic door poper, do away with the door handels and locks all together.
muddslide
505
DAYTONA BEACH
May 7, 2004
  • May 7, 2004
Thats what I did, looks great but I don't have any pics. It almost looks factory
brianj5600
1,964
Middle TN
May 7, 2004
  • May 7, 2004
I'm cutting my dash. It is my car and I want the cd player accessible to me when I drive. If the next guy wants to repair it, ok. I don't want to deal with trying to operate the hidden radio, I want to enjoy my car.
TRICKFastback
28
Arizona
May 7, 2004
  • May 7, 2004
DONT CUT YOUR DASH!!
I have a 67 Fastback, and in my car I ordered a 1967-68 Radio Bezel from Mustangs Plus Part# 01994, then I took the Player Bracket and inset it against the Radio Bezel. I used a Marker to trace around, and used a Cut-Off wheel to get the exact fit. It looks like it came from the factory.
K
kyle67
60
Baton Rouge, LA
May 7, 2004
  • May 7, 2004
Metra makes an under-dash kit that looks nice and works well in a 67 if you don't have a console. They are about 20 bucks.
'69Mach1Chick
There's no grass left to cut.
Apr 1, 2002
348
North Jersey
May 7, 2004
  • May 7, 2004
I have a 70 and i just pulled of the stock panel and went to the metal shop and had a custom fit plate made. Then i layed the cd changer on the backseat and put speaker boxes on the back deck under the window. Easy enough. They sell plates and panels that you can put in but they aren't really worth it.
67CoupeDriva
165
South Carolina
May 7, 2004
  • May 7, 2004
if you don't have a console, the 67 uses a seperate bezel for the radio, making the repair of a cut one much easier. You can probably buy a used one off of ebay (maybe even already modified...that's where I sold mine when I put a console in) and cut if if necessary and keep the original. Or cut the original if the finish isn't so hot and buy a repro one for later.
Myfirst67
88
May 7, 2004
#10
  • May 7, 2004
  • #10
My cd player will be accessible because it came with a remote,but the reson i want it in the glove bow is because i want the stock look.
Dark Knight
2,578
Chandler, Az.
May 8, 2004
#11
  • May 8, 2004
  • #11
mustangs unlimited just came out with a CD player that has a bezel too, bolts into the stock location.. no cutting.. made by blaupunkt .. for non console cars
http://mustangsunlimited.com/aspfiles/default_frame.asp?UID=2004050809580941
about time too..
none67
352
#12
  • May 8, 2004
  • #12
i don't see why everyone is so up tight about cutting the dash. i mean people cut open hoods, 1/4 panels, frames, various body parts.. everything really, yet for some reason everyone is afraid to cut the dash, can some fill me in? its really not that big of a deal
G
GypsyR
87
SC
May 8, 2004
#13
  • May 8, 2004
  • #13
67 and 68 cars are the easiest to install CD players into. I found a used bezel at a swap meet that had been patially hacked to apparently fit som older cassette player. Got it really cheap and it was no big deal to grind and file it out some more to fit my Kenwood Excelon. I did have to sand one corner of the snap on trim plate a bit, but it's unnoticeable. looks and works just great.
The best part is I can take out 4 screws, disconnect the wires and plop my original bezel and AM radio back in anytime I want.
taylor4g63
921
Asheboro, NC
May 8, 2004
#14
  • May 8, 2004
  • #14
I just cut the little radio bezel, no big deal. Take a dremel to it and it takes maybe 10 minutes. I've got plenty of pics of mine if you want them. My host is being weird right now so i can't do that and they are too large to attach, so if someone wants to resize em or host them let me know and ill email them.
Myfirst67
88
May 8, 2004
#15
  • May 8, 2004
  • #15
I can host the pics for you taylor mail the to funyun00@hotmail.com or funyun000@yahoo.com
muddslide
505
DAYTONA BEACH
May 8, 2004
#16
  • May 8, 2004
  • #16
here is a pic of mine cut, no big deal.
hungrymonkey
12
108
Oregon.
May 9, 2004
#17
  • May 9, 2004
  • #17
pre 67 cars had the stock radio mounted in the dash, to cut them you would have to make a permanent hole. It could be fixed with installing a dash from a donor car, or a patch panel.
67 and up cars have removable bezels that the stock radio was mounted to.
65StangBoy
247
Phoenix, AZ
May 9, 2004
#18
  • May 9, 2004
  • #18
I couldn't bring myself to cut the stock dash so I bough an underdash housing and just flipped it upside-down. Worked perfectly for my needs. Let me know if you want bigger pictures.
<img src="http://members.cox.net/stangboy1965/pictures/car/interior2.jpg">
<img src="http://members.cox.net/stangboy1965/pictures/car/interior3.jpg">
muddslide
505
DAYTONA BEACH
May 9, 2004
#19
  • May 9, 2004
  • #19
I just don't think this is a big deal to install a cd player. Its not like your cuting up your car to install a tv or magic 8 ball. It's your car, if you want a cd player put one in.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
