wherer is my trans fluid leaking from?
sometimes there is a little blow off valve on top of the trans...that could be it. Best thing to do is to wipe it completely down and then follow the trail. There is nothing on the pan? What about the oring for your dipstick?
I had similiar problem - ended up replacing seal around the shifter linkage where it goes inside tranny. I have also seen the cooling line fittings leak where they connect to the xmission.
Another thing to check is the speedometer cable. Pull it out and check the o-ring seal. Also check cable itself to make sure there are no cuts or breaks in it near where it goes into transmission.
_______________________________________________
70 Mach 1
351c
FMX
I once had a 69 that only leaked when the tranny-engine was under a back pressure type situation, for example when going down hill under a coast. I dropped 2.5 quarts when going down Pikes Peak. The thing looked like it was on fire as the fluid went all over the exhaust pipe. A new rear seal fixed it. If it is still coming from there, was the seal installed correctly?
