Wheres My Bottom End
I had someone pushing on throttle to check and make sure butterfly opened up the hole way. And that the linkage from throttle down to tranny was not loose and opperating properly. Replaced and checked for air leaks around vaccum lines and intake
I didn't replace cable just made sure it was adjusted corectly and moving. Used a snapon tool almost like a tech2 dumped old codes no new codes right now. I did just aquire a fuel pressure reg. That's adjustable. I'm gona put that on recheck fuel pressure.
Any opinions on torque converter being damaged from the exhaust being welded and the ground wire not at right spot and warped or the bearings in it from the electric flow from welder.
I've mig welded on hundreds of cars with absolutely no ill effects, new, old, computer controller, etc. This is not your problem. Tig welding is a different story and I always disconnect the computers and pull them out of the car entirely before Tig Welding at all.
I may not have any other valuable input here, but Mig welding exhaust is not the problem.
Reactions: Rick 91GT
110% agree
Sent from my XT907 using Tapatalk 2
Why do you think they make isolator tools for electronics when you weld on cars that have sesitive electronics. I seen first hand computer chips fri from just static and your telling me that if someone doesn't ground the mig at the right spot its not gona fry whatever small electrical things the current passes through. Hahaha
Oh and I was gm certified up until 2001 then went construction route cause it payed more
sounds like you are more qualified than us. good luck getting that soda bottle to jump out of the cup holder. Peace :drink:
