wheres the VSS located????
  • Thread starter Thread starter MustangGT92
  • Start date Start date Jun 7, 2006
MustangGT92
89
Oklahoma City
Jun 7, 2006
  • Jun 7, 2006
in one of the earlier threads someone mentioned a VSS( vehicle speed sensor) that controls the rpm's on the car... i was just wondering where this was located and how much they are....
U
uneverkno
65
  • Jun 7, 2006
its on the tranny near the crossmember. theres some on advance autos site from 18 to 78 dollars
MustangGT92
89
Oklahoma City
Jun 7, 2006
  • Jun 7, 2006
is it on the driver or passenger side of the tranny....
bubba-dough
1,044
Indiana
Jun 7, 2006
  • Jun 7, 2006
drivers side
dw89lx
44
Boston, MA
Jun 7, 2006
  • Jun 7, 2006
When does the VSS control the RPM's? I thought it only works with cruise control.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 7, 2006
  • Jun 7, 2006
A bad VSS sensor will set Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. The VSS is used to tell the computer to speed up the idle as you slow to a stop. This helps keep the engine from stalling when you slow down for a stop sign or stop light.
Check to see if the electrical connector is plugged into it. Clean the connector & contacts with non flammable brake parts cleaner prior to replacing the sensor, as that may fix the problem. The sensor cost is under $30 and it is easy to replace.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
N
Trying to locate 1968 Mustang
  • Newton
  • Jul 1, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 1, 2026
Newton
N
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
