  • 1994 - 1995 Specific Tech
Which c/c plates?
  • Thread starter Thread starter 311green94
  • Start date Start date May 28, 2005
311green94
22
  • May 28, 2005
I am gonna hit my suspension as my next project and wanted some input. I searched the forums, but couldn't find the right answer. I am going with the following suspension setup:
H&R Super Sport Springs
Bilstein shocks and struts
some kind of offset bushings
I want to know which c/c plate I should go with. I am not going to be road or drag racing the Stang, but I dont wanna chimp out on parts. Whats the difference between 3 and 4 bolt? I saw that UPR had some c/c plates for like $150 and then MM had a set for $160. Eventually, I am gonna switch to a AJR tublar k-member, but was still going to run the H&R springs with the modified perches. Any thoughts?
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
May 28, 2005
  • May 28, 2005
A 3-bolt plate would be fine if you are never going to do coilovers. However, I would recommend the Maximum Motorsports 4-bolt plates no matter what your long term plans are. The suspension is one place I refuse to skimp on, because a part failure can mean the end of your car and maybe you along with it.
91LX_5L
1,943
British Columbia
May 28, 2005
  • May 28, 2005
MM cc plates are awesome
A
Al J
307
North Providence, RI
May 28, 2005
  • May 28, 2005
MMs are noisy.
Steedas are not---says the guy who had both.
MysteryMachine
1,835
Parkesburg, PA
May 28, 2005
  • May 28, 2005
You can get UPR 4 bolts for like $136. Thats what i ordered. All this talk about 4 bolts all the time figured what the hell i'll get them even if i don't really need the extra bolt.
BUT if you looking into the UPR 4 bolt call and ask if they have them first.
Mine were ordered they gave a tracking # then I ordered another part and the trackign number was cancled and i got a new one. I figured they put both in the same box. Got the 1 part but not the plates called they said they were out of stock. Been about 2 months now found out wed the had a set sent back to them that were shipped out wrong so i'm getting them. Should have them on Tuesday. Would have been nice if they would have just told me in the begining they were out
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
May 28, 2005
  • May 28, 2005
I have MM. I love them. Noisy though.
Dustin
Car Nut
1,176
Snellville, Georgia (Atlanta area)
May 28, 2005
  • May 28, 2005
MMs noisy??? Not mine at all. When did you guys get your MM C/C plates? I got mine last August, so maybe they are an updated design.
I'd recommend MMs aluminum center-drilled rack bushings. Check out MMs website and read why they swear by center-drilled bushings for most circumstances. Heck, the parts you already mentioned above are sold by MM. Go for it, you won't be dissapointed.
94TURBO5 O
2,509
VA
May 28, 2005
  • May 28, 2005
MM makes some great CC plates and was going to get them when I was in the market but the Hotchkis ones won me over.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 29, 2005
  • May 29, 2005
Hotchkis has a great 3 bolt cc.
baglock1
The Bartender
6,612
Space Coast, FL
May 29, 2005
#10
  • May 29, 2005
  • #10
Any cc plate that uses a solid spherical bearing will be noisy. One that is less noisy means that it uses bearings that have looser tolerances.
Noisy = solid = quality. If noise is a major concern, stick to a plate that uses a rubber isolator. If you want the performance, you are going to have to pay the price.
And trust me, you guys don't know noisy until you have nothing but solid links in the suspension. Ask me how I know.
F
fiveo'cobra
241
SC
May 29, 2005
#11
  • May 29, 2005
  • #11
I have the D&D 4 bolts with solid bushings. Its really not THAT bad but you can tell the difference. They are great quality and fit was perfect. I don't see the difference between these and MM's except for the fact that you pay for the name with the MM's.
311green94
22
#12
  • May 29, 2005
  • #12
Thanks all. I was going to go with the MM 4 bolt design and looks like the majority rules. Thanks again.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
