Which Cam Dowel?
I don't remember which one I used John :shrug:
I just measured the depth of the hole in the shaft and the thickness of the other stuff for the total length needed.
One other thing ......
Don't force the pin in the cam if it is too tight and then realize you need to take it out.
I did that once upon a time :fuss:
It was not pretty :nono: and a whole lot of :bang: ...... :rlaugh:
Grady
The shorter dowel is for late model application, the longer dowel stick out past the gear and was used for the fuel pump ecentric in the old models.
The pin should fit tight in the cam, and should be tapped in with a brass hammer.
Yeah right after i posted this i did a search and found an older post that you replied to. Good stuff Rick.
