Which Caster camber plates?
FordStang said:
how do i know each side is adjust and aligned right??
Well, if you have to ask that it means take it to an alignment shop and have them do it. The install is easy and pretty straight forward using the directions. Keep in mind though that you have to drill a hole in the strut tower for the install. That doesn't agree with some people (why, I don't know) but the real benefits of the 4-bolt plates are worth it.
FordStang said:
another question, reason im getting this camber plates is because i removed my strut tower brace and dont really want another one so will this tighten up my front a little bit for when i go around corners ect??
The CC plates won't do anything to "tighten" up your front end. They'll allow a wider range of adjustment of your alignment settings and they'll have a tighter tolerance (more precise) as there isn't any flimsy rubber to distort and allow the settings to move around. Ultimately, a better alignment will put more rubber on the road and that is what promotes better handling.
And I wouldn't worry too much about the strut tower brace. I haven't taken mine off just because I'm lazy and I'm not positive it doesn't help. But I'm not sure it really promotes any appreciable chassis stiffening. The jury is still out on that one IMO.
I took my strut tower brace off when we changed the intake... I would NEVER drive my car without it. That thing handled terrible....
It's what... 8 bolts. I say try it before you decide it's worthless. I've been told they make no difference and I have to completely disagree.
FordStang said:
i didnt feel like buying a new Strut tower brace, GcokmFx look at Sig and mods....stock one wont fit.
And??????? I don't get what you are saying to me. :shrug:
You were asking about tightening up your suspension for cornering..... so I gave you my opinion about the removal of your ST Brace. My stock one won't fit either and is collecting dust in the corner of the garage.
Sorry for the harsh comparision, but it's all I can think of right now:
Just because my front brakes don't fit the cheaper 3.5" Skinny wheels for drag racing due to our calipers being too big, doesn't mean I plan to buy some and remove my calipers and try to think of other ways to make my car stop cheaper. IMHO some mods REQUIRE changes and other parts. They should be looked at as a kit. If you can't afford one, then don't install the other until you have everything you need. I personally feel the ST Brace is needed. If you are looking to tighten up your suspension in the front, you apparently are missing it too. :(
I got a good deal on a used one from BrothersPerformance. Since I have a 96 Cobra hood, I had to have it modified by a local welder... but I still wouldn't drive my stang without one. I tried it..... it's not for me.
I have the Hotchkis CC plates and a complete poly bushing kit sitting at the foot of my bed waiting for my bullitt suspension kit thats on backorder for about 2 months now!!!!! :mad:
I will let you all know how it handles when I get it and get it all on!!!!!! :nice:
Donny
Donny
Where did you order from? Just curious as suspension is down the road for my car....
