Which Caster/camber Plates.
Hi guys, I'm going to finally get some cc plates mostly because car pulls pretty bad to the right and alignment shop says that's as good as they can get it with the little amount of adjustment in the stock setup (car has been in a couple of accidents, one good one so I'm guessing that's why they can't get it to "track" straight).
At any rate as you know they're are some on eBay for $75... are the MM plates worth the extra $??
I don't want any noise and the cheaper ones look to have only metal bushings where the MM have poly or rubber..not sure.
What are you guys running?? suggestions please.... thank you!
Steeda is my choice - all steel, spherical bearing at the top of the strut.
Stay away from aluminum CC plates if you live in one of the places that is plagued by pot holes.
Reactions: mikestang63
As mentioned above two things
1. before throwing parts at it- you need to check if your suspension parts or subframe are in need of repair.
2. Spend the extra money and get the MM ones- do not cheap out on suspenson or brake parts
