  • SN95 4.6L Mustang Tech
Which CC Plates?
  • Thread starter Thread starter stangGT97
  • Start date Start date Oct 25, 2005
1 of 2 Next Last
stangGT97
1,299
Boston area, MA
Oct 25, 2005
  • Oct 25, 2005
Hey guys... my car is lowered over 1.5" and the front tires are leaning in, and when I went to get an alignment they told me that caster/camber is not adjustable. So naturally the only remedy would be to get CC plates. Just wondering what you would recommend to me? I know a lot of people are running maximum motorsports' plates, but do I need to get that fancy if all I want is to just straighten my tires? Also, if you think those are the only way to go, then do you need to use the 4th hole because I know that requires drilling? Thanks in advance!
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Oct 25, 2005
  • Oct 25, 2005
If you're going to buy a 4 bolt caster camber plate, might as well do the drilling and make use of the 4th hole while you're in there........ok, that sentence sounds kinda perverted, but we'll pretend it doesn't.
Seriously though, Maximum Motorsports is a really good brand, but I hear good things about UPR, QA1, and Steeda Caster camber plates as well. I think pro3i makes a set, but not sure. There are other companies as well, so you might want to do some browsing.
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 25, 2005
  • Oct 25, 2005
do it right the first time, get the MM c/c plates
propellerhead
1,541
"but what's with the but shots?"
Oct 25, 2005
  • Oct 25, 2005
I have a friend who installs them. He's had to send two UPR shark ones back to UPR.
hotrodnut
672
North Florida
Oct 25, 2005
  • Oct 25, 2005
I'm happy with my 4-bolt Aluminum Steeda's. They have been installed for 2 years now and no problems.
scalder
375
Dallas/Plano TX
Oct 25, 2005
  • Oct 25, 2005
x2...very happy w my 4 bolt Steeda...
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 25, 2005
  • Oct 25, 2005
Very happy with my Pro3i C/C plate
hotmustang331
2,967
Bastrop,TX
Oct 25, 2005
  • Oct 25, 2005
Well, I just ordered a full tubular K kit with coilovers...so I have been in the market for some nice CC plates since all the loadwill be on the strut towers and CC plates. I looked over 2 main companys... MM 4 bolt CC plates and the steeda 4 bolt CC plates.
AND IMHO THE STEEDAS ARE BETTER. After looking over things such as weight (steedas 7075 aluminum is MUCH lighter then MMs thin steel and about the same strength) and ease of adjustability....the steedas seem much better and more advanced.(and they look MUCH better to boot)
And MMs reason for not using aluminum was so they could use a thinner cut of metal (steel) and RETAIN the strength for less bump travel(not a good reason IMO). SO apparently they are the same strength and since the steedas also fits under the hood and their height can be adjusted W/O using shims...the choice was clear.
The steedas are more expencive though...but you get what you pay for I always say. (I looked for HOURS and got them for $229 shipped...normally go $249...and that wasnt on Ebay either)
But since your not getting coilovers, you can get steedas aluminum 3 bolt CC plates for $180ish...they will work fine. No need for the expencive 4 bolt stuff, the above was just incase you WANTED only 4 bolt.
BennyBlown2v
1,233
Carmel, INdiana
Oct 25, 2005
  • Oct 25, 2005
Maximum Motorsports 4 bolt, I love them and so does my alignment shop
MT1083
1,033
Charlotte, NC
Oct 25, 2005
#10
  • Oct 25, 2005
  • #10
I've had no problems with my mm plates.
stangGT97
1,299
Boston area, MA
Oct 25, 2005
#11
  • Oct 25, 2005
  • #11
so what exactly is that 4th hole for anyway? In case you're using a coil-over setup?
squares98
852
Orange,ca
Oct 25, 2005
#12
  • Oct 25, 2005
  • #12
I had steedas and now I have Max Morotspororts c/c plates and I love them. That should tell you what I think about the steeda c/c plates. Like Tomustang said " do it right the first time".
edit: I had the three bolt steedas, which everyone with experience knows are junk, Unlike the 4 bolt variant.
5.0zone
22
Kenly, N.C.
Oct 25, 2005
#13
  • Oct 25, 2005
  • #13
I have the 4 bolt Steeda - like em - adding the 4th bolt isn't that bad.
You don't realy need a 4 bolt plate unless you run a lot of + caster.
I'm running 285/40/17 on the front so I needed as much +caster as i could get. I pushed them as far back as they would go, then matched them up.
P
PEWTERPONY
829
NE Atlanta
Oct 25, 2005
#14
  • Oct 25, 2005
  • #14
I have the Steeda 4 bolts too.......Glad I got them when I put the PRO KIT on...Happy with all of it!
97yelstang
43
Schuykill Haven, PA
Oct 25, 2005
#15
  • Oct 25, 2005
  • #15
steeda is what i have. I've had no problems with then either
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 25, 2005
#16
  • Oct 25, 2005
  • #16
steel>aluminum. strength. the only thing steeda's got over MM is the weight.
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 25, 2005
#17
  • Oct 25, 2005
  • #17
the forth bolt is for more structure everywhere on the tower
hotmustang331
2,967
Bastrop,TX
Oct 25, 2005
#18
  • Oct 25, 2005
  • #18
Well thats true...but when the aluminum is about twice as thick as the steel...its hard to say which is stronger. And since im going for light weight the steeda really had me sold once I found out the MMs where steel. I really wouldnt pay $50 more for the steeda if I didnt think it was worth it...especially since everyone says MMs are the best. But since neither will break or bend under the load, I went with the one that looks better and weighs ALOT less.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 26, 2005
#19
  • Oct 26, 2005
  • #19
see sig nuff said
stangGT97
1,299
Boston area, MA
Oct 26, 2005
#20
  • Oct 26, 2005
  • #20
bdcardinal said:
see sig nuff said
that doesnt help? haha. Well, it just seems that Steeda's stuff is way over priced. And how much is the weight difference? I doubt it would ever be noticeable
1 of 2 Next Last
Suspension CC Plates bushings and sleeves?
  • Scott_S
  • Apr 16, 2026
Fox 5.0 Mustang Tech Apr 16, 2026
Mustang5L5
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
