Which Clutch? Flywheel??
  • Thread starter Thread starter steveb24
  • Start date Start date Mar 8, 2007
steveb24
555
wilmington, DE
Mar 8, 2007
  • Mar 8, 2007
So with the headers im gettin a new clutch put in, and ive been held up cause i cant decide wheather i want a STG 1 or 2 SPEC clutch. I will not be doing any more performance mods to this car for a long time, so keep that in mind. This car is goin away with me to finish up college for the next (up to 3 years). i need it do be as DD able as possible, and to hold up and be reliable. So basically, i would like the lighest pedal effort, and the saving of $100 isnt bad either. I dont cheap out tho when it comes to the stang at all, and i never will, its just that why should i get a stronger one if i dont need it? thats what im thinkin / wondering if itl be beneficial. also, what should i do about the flywheel. My performance shop will resurface it for $35, or i can get a steel one, which is $235.. again, more $$ i dont want to spend, but if "necessary", i will. thanks :SNSign:
Stangdriver13
44
  • Mar 8, 2007
My friend has a 95 firebird with a spec stage 3, and his pedal effort didn't increase much but his friction point was cut down to bout a quarter of what it was before. Thing grabs like no other now though and guaranteed to chirp the tires through third gear. I have drove it once and i did not like how+ the friction zone was so touchy. Like it was engaged or it wasn't, no slipping at all. As far as if it is necessary to get a stage 2 over a stage 1 i would say it depends how you drive your car. If your doin a lot of high rpm drops then a stronger clutch would never hurt but one thing i would keep in mind is that a clutch that grabs harder means it puts more wear and tear on your tranny and rearend.
A
aggiedj02
165
Las Vegas, NV
Mar 8, 2007
  • Mar 8, 2007
i have a DF Centerforce sitting at home waiting to be installed. I heard that SPEC clutches were iffy on quality so I decided to spend a bit more up front to potentially save myself money later on. Also the pedal feel on the DF is suppose to be better than stock. I guess I will find out. I have LT's so I don't feel like redoing this job if I dont have to.
You might want to think of dropping the extra dough now so you dont have to replace a crappy clutch later on.
SyberSaint
252
San Antonio, Texas
Mar 8, 2007
  • Mar 8, 2007
Today, I started a thread something like this on 4.6 Tech. I am asking for comparisons on the SPECII and the SPECII+ (Plus). They are pretty much the same, but handle different tourqe ratings...
steveb24
555
wilmington, DE
Mar 8, 2007
  • Mar 8, 2007
o ill check that... im kinda wondering about the STG 1 tho.. since thats where im leaning.. anyone got exp with it??
M
maverick0011
26
  • Mar 8, 2007
Man ive got a 2000 gt with a spec stage 3 and i love it. Great at the track and very streetable. I used the stock flywheel and had it machined and i love it.I know i could have got a flywheel but i was out of money. I think the spec stage 3 was like around 300.
steveb24
555
wilmington, DE
Mar 9, 2007
  • Mar 9, 2007
thats good and all.. but i dont think i wana get any more than i need. These parts are designed for certain power levels, so whatever your level is, thats what you should get. correct me if im wrong. only time i would think to go bigger and better is when ull need it down the road. anyways, more feedback on spec's if anyones still around..
SyberSaint
252
San Antonio, Texas
Mar 9, 2007
  • Mar 9, 2007
steveb24
555
wilmington, DE
Mar 10, 2007
  • Mar 10, 2007
so am i good with the gettin the stock flywheel resurfaced?
F
frank13
#10
  • Mar 10, 2007
  • #10
I dont mean to hijack your thread, but i just asked a similar question. I also have a 2002 gt and need a new clutch ,
Do you think this would work for you/me
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=3693
Comes with clutch and flywheel, made for 11 cobra's
Again sorry for stepping on your toes!
Frank
steveb24
555
wilmington, DE
Mar 10, 2007
#11
  • Mar 10, 2007
  • #11
well as somebody said in your thread.. that dosent include the flywheel? i ask because i didnt look into it, but resurfacing a flywheel compared to buying a new stocker is basically the same thing. im wondering about the steel ones tho, but just dont think its worth it. as far as a new clutch and TOB, if thats what you want than itl work great. they work fine for 100K miles the first time, why wouldnt they do it again? i do make a bit more power so im going toward the aftermarket, but i dont want to over estimate and be stuck with a stiff and choppy clutch.
TweekedGT
1,274
Alberta
Mar 10, 2007
#12
  • Mar 10, 2007
  • #12
I've had a Centerforce Dual Friction clutch in my car when it was at 290rwhp and I really liked it. It didn't fail but when I changed the motor and put the blower on I changed to a Spec Stage 3 and a new flywheel to handle the torque. The Spec Stage 3 didn't las't 4 months and it blew up. My parts dealer said they have had nothing but problems with Spec's failing as of late. I guess it never used to happen but lately the quality has really slipped it seems. I just got a Mcleod this week, it's going in this Friday. I've been told they are the best on the market for both quality and warrentee.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
