Which distributor for 332 stroker
  • Thread starter Thread starter Reef
  • Start date Start date Jan 10, 2010
Reef
25
FRANCE
Jan 10, 2010
  • Jan 10, 2010
Hi Stangers,
I've a 332 stroker on 66 Mustang and the distributor is faulty.
My cam is E303 from Ford Racing and my oil pump is a Milodon HV.
I want to buy MSD distributor but I don't know which one to choose ?
What is your opinion about Ford distributor with Milodon HV oil pump ?
I know that the distributor gear don't like HV pump...
Thank you,
Reef
brianj5600
1,964
Middle TN
Jan 10, 2010
  • Jan 10, 2010
What is the motor built for? Street? Roadrace? A stock distributer is fine for a street/strip car. If you are buzzing it 7500rpm it might be worth buying an MSD distributer. I would worry more about the HV pump breaking the drive shaft than the gear. Make sure you have a heavy duty oil pump shaft and the correct gear for the camshaft type and you should be OK.
D
D.Hearne
11,730
south louisiana
Jan 10, 2010
  • Jan 10, 2010
You need a steel geared distributor and a HD oil pump shaft. The stock distributors are fine to 7500 with a Pertronix or the stock Duraspark units. If you go with a Duraspark setup, fresh reman steel geared distributors can be bought locally, you want the 85 Mustang HO with manual transmission distributor (around $55-65 with a core distributor in trade, doesn't have to be a Duraspark unit)
CraigMBA
783
Orange, CA
Jan 10, 2010
  • Jan 10, 2010
Call the MSD tech line and describe your setup. Buy what part number they recomend.
dcstang67
127
  • Jan 11, 2010
MSD #8598 will work. It has a steel gear for roller cams and works with an MSD ignition box. I have one for sale in the classifieds and I am asking $175 or B/O for it. It is like new with only 2000 miles on it. I removed it so I could go with a stock style fuel injection.
Reef
25
FRANCE
Jan 11, 2010
  • Jan 11, 2010
332ci distributor
Hi guys,
First, thank you very much for reply.
It's street/trip engine :
* 332ci strocker (code K)
* Edelbrock Performer RPM Manifold
* Elelbrock Victor Jr heads
* 11.25 JE pistons
* Eagle beam
* Nitrured crank
* MSD ignition (MSD6AL + Pertronix)
* Holley 750 carb
* 303E cam (before 290HR from CompCams)
* Pro Magnum Comp Cams lifter/springs/rockers
* Milodon oil pan with high volume pump
* Mallory gaz pump
* Griffin alu radiator with 14" electric fan
* Pete Jackson belt drive
How say CraigMBA, I going to ask MSD TECH about it.
I prefer to buy MSD than Ford, it's more serious
=> I tested bronze gear : 5000 kilometers
=> Iron gear : 10 kilometers ! (distributor faulty axle...)
Which oil pump advice me ?
Thank you,
Reef
D
D.Hearne
11,730
south louisiana
Jan 12, 2010
  • Jan 12, 2010
Reef
Well it's your money your wasting.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
R
1974 Datsun 620 pickup / 5.0L HO
  • RJH46
  • Aug 24, 2025
  • Other Auto Tech
Other Auto Tech Aug 24, 2025
