  • SN95 4.6L Mustang Tech
Which gear is better?
  • Thread starter Thread starter Fly Society
  • Start date Start date Sep 1, 2009
F
Fly Society
10
  • Sep 1, 2009
I have an 01 GT automatic andi dont know which gear to go with.... 3.73 or 4.10..... What arethe pros and cons for each and which is best for my car considering I have a automatic?
trinity_gt
3,125
81
99
Canada
Sep 1, 2009
  • Sep 1, 2009
You'll hear a million opinions but for an auto, I'd go 4.10s.
G
GettinThere
553
Central Texas
Sep 1, 2009
  • Sep 1, 2009
VEE EIGHT
85
Texas
Sep 1, 2009
  • Sep 1, 2009
For an auto, definitely 4.10's. I will GUARANTEE that you will regret going with anything lower than that.
R
ran260gt
365
  • Sep 1, 2009
GettinThere said:
4.30
Worst move ever ^ , the 4R70W will not last long shifting into O/D well short of the 1/4 mile mark !
4.10s make 3 gear good for around 110mph +or- depending on tire size and a few other things , shifting into 4 gear ( O/D ) at full blast is very bad for your 4R70W !
If you plan on a S/C or some other heavy mods go with 3.73s ,this way you can stay in 3rd for the 1/4 , because the odds are your going to trap at a higher mph the 110 !
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Sep 1, 2009
  • Sep 1, 2009
id go 4.10's i always swore by 373's, except i just put 4.30's in my car and love them, its make the car feel like a real muscle car, not a heavy tank!
twogts4us
4,188
12
79
Dunedin, FL
Sep 1, 2009
  • Sep 1, 2009
G
GettinThere
553
Central Texas
Sep 2, 2009
  • Sep 2, 2009
ran260gt said:
...shifting into O/D well short of the 1/4 mile mark...
I'm not familiar with the automatic transmission, there's not a way to deactivate the OD?
trinity_gt
3,125
81
99
Canada
Sep 2, 2009
  • Sep 2, 2009
I'm not sure what it is about the 4R70W that makes it unhappy with such a condition as ran260gt alleges (maybe he's thinking converter clutch lockup?) but the problem is that if you force the trans to stay in 3rd gear (1:1), then the restriction becomes engine RPM: If you've got a car going through the traps at 110MPH then with 4.10s the engine RPM would be in the range of 5800, very close to redline but technically below it.
If you went to 4.30s and still forced 3rd gear, you'd be at ~6100RPM, in excess of redline (at least for the stock internals...)
C
clrgt
missouri
Sep 2, 2009
#10
  • Sep 2, 2009
  • #10
it depends is it a daily driver or what other mods do you have? i went with 3.90s and love them moe bite than the 3.73s i had and still get great crusin speed for the weekend runs. but i think that u need to decide what other mods u want if your stock and dont plan on any major power mods then 3.73 is best.
40oz
499
Minneapolis
Sep 2, 2009
#11
  • Sep 2, 2009
  • #11
Obviously the stock cams aren't designed to make power up there, but the 05+ cars have the same crank and rods and spin that rpm safely. If that's what a person has to do to get across the traps without shifting, I wouldn't worry about rpms. Obviously if one is hitting 105+ mph across the finish line, the engine is seeing more stress from power than from turning a few hundred rpm above stock.
R
ran260gt
365
#12
  • Sep 2, 2009
  • #12
The 4R70W first three gears are clutch packs , the O/D is a band , this band is much weaker then a clutch pack , if you shift from 3 to 4 at full throttle you are at risk for blowing your O/D !
With the stock 4R70W you want to stay in 3rd gear in the 1/4 mile at all cost , with the 4.10s 3rd gear is only good for about 110mph depending on tire size ,so If you plan on going over 110 in the 1/4 , go with 3.73
If you plan on staying under 110 in the 1/4 , go with 4.10 !
CobraRed_96_GT
1,421
UCSD/La Jolla
Sep 2, 2009
#13
  • Sep 2, 2009
  • #13
+!, even on a built trans like mine. You have a kevlar band then you risk twisting the input shaft into licorice.
GDawg
1,469
Nevada
Sep 2, 2009
#14
  • Sep 2, 2009
  • #14
4.10 ...if he's a GT stock. If he's more, he wouldn't be asking this question.
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
Hi from Western Washington
  • Bannister
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 31, 2026
keel
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
