Which gear oil
  • Thread starter Thread starter grego37
  • Start date Start date Jan 9, 2006
G
grego37
576
Fresno CA
Jan 9, 2006
  • Jan 9, 2006
Im about to put my 3rd member back in, which gear oil is the best.
It has a Locker, and is in a street car.
thanks.
rbohm
6,698
550
204
tucson,az
Jan 9, 2006
  • Jan 9, 2006
any good synthetic oil will do fine. royal purple seems to be popular right now, but i still like the old stand by pennzoil. as far as weight goes, 75W90.
fasttback
471
Northern CA
Jan 9, 2006
  • Jan 9, 2006
I ran Redline synthetic 75w-90 with some additional friction modifier in my 9" w/ trac-loc. Works fine, but synthetic oils (as I have learned) are more prone to leak than conventional oils.
rbohm
6,698
550
204
tucson,az
Jan 9, 2006
  • Jan 9, 2006
actually when you switch to synthetic oil and have a leak pop up, the leak was already there, just plugged up with sludge.
milner351
92
The Motor City
Jan 9, 2006
  • Jan 9, 2006
As I recall you don't need to use the friction modifier with the locker, sinc it's mechanical / sprag lock, not friction disc lock like the trac-lock.....
correct?
Another vote for synthetic gear lube here. Valvoline, Amzoil, whatever you can get off the shelf, 80-90w or 75-140w.
G
grego37
576
Fresno CA
Jan 9, 2006
  • Jan 9, 2006
Correct no friction modifier with a locker.
UPDATE:
I called Currie Enterprises , they highly reccomend NOT to use synthetic in the rear end. They said that the Ford 9 inch it has more hypoid angle than other rear ends (or something to that nature) I guess its the angle that is on the gears,and the synthetic doesnt work as well as non-synthetic in this case. They also said to run 75/140 wt.
Im going to take their word on this one and use 75/140 conventional gear oil, with no additives.
I can smell it already.
thanks for the feedback
1969mach1351
285
Sacramento, CA
Jan 9, 2006
  • Jan 9, 2006
Anything already listed is fine. The shop I got my locker from had me use Valvoline 75w 90 which I believe is synthetic.
thehueypilot
1,084
Medina,Tennessee
Jan 9, 2006
  • Jan 9, 2006
They "Currie" told me the same thing and that my case was leaking because I was running synthetic gear oil. I ignored them and ran it anyway but went with 140 wgt synthetic. I took it apart last month to change out the gears from 4:11 to 3:55 and the leak was a chunk missing out of the pinion support which took a chunk out of the o-ring that seals the case. Someone at Currie dropped it on the floor and slapped it togather. Great Quality...
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Dipstick Issue?
  • Sonic
  • May 2, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
