  • 1994 - 1995 Specific Tech
Which head gaskets to get?
  • Thread starter Thread starter 1105
  • Start date Start date Dec 19, 2003
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Dec 19, 2003
  • Dec 19, 2003
Hopyfully I'll have enough money left over from my check to buy the stuff I need to put on my TW heads. I allready have the part # for the ARP head bolts, so now I need a part number for the head gaskets. If you know which ones to get just post it and I'll try to find out the part number if you dont know it. I want to get a nice set so everything seals nicely.
Heres a list of stuff I'm going to need, add to it if I'm missing anything.
ARP Bolts
Head Gaskets
Valve Cover Gaskets
Lower Intake Gaskets
Header Gaskets (maybe)
Timing Chain Cover Gasket
Timing Chain Set
My upper to lower intake gaskets are still fine, they are only about a month old so I dont need new ones of thoes. I think I might be missing a few things so please let me know if I am. Thanks and please dont tell me its going to be over $200 because then it'll have to wait until after christmas
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 19, 2003
  • Dec 19, 2003
Here is what I got, and how much it cost:
FPP-1011-2, Fel-Pro Head Gaskets, $60
ARP-154-3701, 12pt Head Bolt Set, $40
FPP-1645, Fel-Pro 1645, 0.25" Valve Cover Gaskets, $30
FPP-1250, Fel-Pro Intake Manifold Gasket, $20
ARP-154-2101, 12pt Intake Bolt Set, $20
FPP-1415, Fel-Pro Exhaust Gaskets, $17
FEL-TCS45449, Timing Cover Gasket Set, $16
ARP-100-9903, Moly Lube, $7
ARP-100-9904, Thread Sealer, $7
Obviously there are some differences, but you get the idea. You'll also need a bunch of oil, antifreeze, distilled water, etc.
Dave
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Dec 19, 2003
  • Dec 19, 2003
like hairycanary said, felpro 1011-2's.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 19, 2003
  • Dec 19, 2003
Whats the Moly Lube used for? Never heard of that stuff before.
Also Dave, wouldnt 6 point bolts be better or ARP doesnt make any 6 point head bolts? As for the intake bolts, I'm currently using the stock ones and they are working fine so should I just leave them for now, maybe change them out later, because I'm on a tight budget right now. Will I also need to pull the water pump? We're putting in a cam at the same time as all of this.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Dec 19, 2003
  • Dec 19, 2003
Aka assembly lube, you use it when you torque down the head bolts to make sure you get accurate torque readings.
ARP makes both flavors. The 12-pt heads are stronger in theory. Just personal choice, really.
Yeah, as long as they're in okay condition. They don't get torqued down all that tight (15-25 ft-lbs). I just had one of mine break when I was taking the old intake off, which is how the ARP ones made my list.
No, you don't necessarily need to pull the water pump. You just have to figure out which three bolts only hold the water pump to the timing cover, and then remove the rest (which go through the water pump, then through the timing cover and into the block). Pretty easy, actually, the three bolts are ones that couldn't possibly go into the block because they'd have to go through important things like timing chains & sprockets .
You will have to pull the A/C condenser out and rotate it up, you don't have to disconnect anything but you need as much clearance as possible -- as it is the cam will just touch the front of the chassis when you pull it out. We just tied it off to the hood support (pics on this page).
Dave
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 19, 2003
  • Dec 19, 2003
thanks Dave
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
Any 1 find any decent blackfriday sales for Foxbody or car stuff?
  • rednotch
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 19, 2025
rednotch
