which header gasket? ordering tomorrow
orangemachine
62
pa
I need to order header gaskets tomorrow morning and I need to know the best ones I can get. I kept trying to get bassani's stainless steel ones but they don't make them anymore. I have mac LTs for my 00 GT 500 rwhp. Any recommondations on what and where to buy?
Percys dead soft aluminum gaskets from summitracing.com . My turbo car has a TON of back pressure...roughly 20PSI+ on the exhaust system before the turbo. And I only had one side blow out after 10K....and well thats my fault.
Front bolt was about a 1/4 inch from the flange teh first time and 0 leaks (hows that for a good seal), so I just tightened it down and that was that. Then a few months later, the same header bolt loosened up AGAIN (+ another one next to it was also hand tight) and it started leaking. So I just replaced the gasket with the same kind.....it took ALOT of abuse and held up great.
Had I checked the bolts (not actuall header bolts) and kept everything tight, it wouldnt have blown out.
So I HIGHLY recommend them....you will never blow them out if they stand up to all the back presure my car makes.
I have Percy's seal 4 good header gasket's on my TBird. I highly recommend them. If you don't go with the them, go with the Motorcraft OEM ones.
^ Awsome. Remember they sell one set for the 2V and one for the 4V. I know I almost didnt realize that they had 2 differnt sets available....just making sure you bought the correct gaskets so you can call them in time if its wrong :nice:
I think stock one is the best one IMO.
Only thing is that stock gasket has this sort of dimple between primary. Which sometimes does not work with some headers (it didn't work with my BBK), because header frange is flat, where as OEM anchor has indentation on frange to accept this
