Which headlight switch wire to tap into?
  • Thread starter Thread starter Loco5.0
  • Start date Start date Mar 3, 2008
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 3, 2008
  • Mar 3, 2008
I'm going to redo my Auto Meter tach wiring. Which wire coming off the headlight switch (LX so non-fog) should I tap into for the light wire coming from the tach?
I
irish
168
Florida
Mar 3, 2008
  • Mar 3, 2008
If you mean the feed for the guages lighting I would pick a source that is dimmed with the dimmer switch, think I used the a/c lighting feed.
Matt
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 3, 2008
  • Mar 3, 2008
Matt
That doesn't answer my question, but thanks anyway
Fett
766
  • Mar 3, 2008
Can't remember the color...I am sure someone will chime in with the diagram. But the easiest thing to do would be to probe the wires with a test light, the one that powers up when you turn the headlights on is the one you want.
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 5, 2008
  • Mar 5, 2008
Anyone?
Nova
128
  • Mar 5, 2008
i nailed the one for the radio, much easier to get to. ill look it up in my EVTM manual this evening if you still need it.
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 5, 2008
  • Mar 5, 2008
I know all about the radio wiring. I have a gremlin so I'm going to rewire...
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 5, 2008
  • Mar 5, 2008
Fett
766
  • Mar 5, 2008
http://www.veryuseful.com/mustang/tech/engine/images/MustangLights-Horn.gif
Use either the Brown parking lights wire or the red/black low-beam wire.
V
v8only
2,378
22
49
Mar 6, 2008
#10
  • Mar 6, 2008
  • #10
It was one of the corner wires... lower left corner wire, maybe one up.....light blue wire, I think with a red stripe. That's the one I tapped into for my dimmer function on my 86.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
