Which is the return and feed fuel lines?
whiteponygt98
293
Midwest City, OK
The title says it all. I've converted to carb and all I have to do is my fuel system. I need to know which of the stock fuel lines is the return and which is the feed. One has a bigger fitting and I think it's called a schrader valve??
Thanks,
Brent
the biggest one is always the feed line. by the way how are you going to deal with the fuel. are you putting an adjustable regulator with a return port on it.
Yes I have a malory regulator with a return line. Both lines look to be the same diameter but one just has a larger fitting... Like I said, they look to be the same size line just the fittings are a different size where they attach to the stock fuel rails.
Brent
