which rev limiter to use?
mustangcobra93
928
I have a crane HI-6S on my car as well as a crane interceptor. Which should I use for my rev limiter, the HI-6S or the interceptor? It seems to me the HI-6S would be the better choice since it takes out spark where as the interceptor takes out fuel, like the PMS and taking out fuel at say 6300 doesn't seem like a good idea to me. I am running a sc-trim vortech on my car. What do you all think?
I'd use the fuel cut especially if you still have cats or are using a wbo2. And the fuel cut doesnt just pull some fuel it cuts it all together so you dont need to worry about running lean or anything.
mustangcobra93 said:
how would you not be lean if it cut fuel?
The fuel is not lean. It is OFF. There is a big difference. Off means no burning fuel at all. Lean is just a little less fuel than optimum, so the burn is hotter. The fuel cut off is much better and less likely to cause damage than the spark cutoff.
