  • SN95 4.6L Mustang Tech
which sub frames for improved drag launch only
  • Thread starter Thread starter 68 & 00 GT
  • Start date Start date May 23, 2004
68 & 00 GT
2,407
HOUSTON TEXAS
May 23, 2004
  • May 23, 2004
I don't care anything about carving corners I just want help with my launch traction so I don't want more than I really need (taking weight into consideration). In about 10 months I'll be ~650 RWHP so I don't know if that needs to be a consideration too. I was looking at Kenny Brown, but heard they only weld to the floor pan. Also looking at MM full lengths. I don't know anything about them so if the weight is not much difference I wont worry about that. I'll be getting something in a few weeks.
What do ya'll suggest considering my goals ?
Thanks-
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
May 23, 2004
  • May 23, 2004
any good sub frame will help drag launches and corning at the same time. a stiffer body helps both. so the cornering aspect won't effect your choice. Steeda and MM both make good sfc, i chose the Steedas because of the torque box plates. the MM's didn't come with them as far as i could tell. if you want to get really crazy, you can have custom sfc's welded into the frame of your car. that's what the sesrious dragsters do. but it is hella pricey.
AdRock
521
South Texas
May 23, 2004
  • May 23, 2004
I bought a set of D&D motorsports subs and thay're very nice construction and didn't cost an arm and a leg. If I remember correctly they were something like $80 shipped. They're the weld in type and I hope to get them in in the next week or two.
68 & 00 GT
2,407
HOUSTON TEXAS
May 23, 2004
  • May 23, 2004
any other suggestions ?
Anyone have Kenny Browns ?
Go HoTO!
602
Mountaintop, PA
May 23, 2004
  • May 23, 2004
You should get full length subs for that much power. Steeda has them. Drop the guys a line at the modulardepot. Quite a few guys there with lots of power. See what they use. No one should really give you advice unless they are running that kind of power.
CTGrey02
1,403
Bristol, CT
May 23, 2004
  • May 23, 2004
I have steeda full lengths with torque box reinforcements. Getting the Tq boxes done while they're doing the welding is prolly a good idea anyway for drag racing. I seriously felt more of a difference doing this mod than just about any of the others. Totally different car and the tires stay planted now.
R
Rocketman
730
SoCal
May 24, 2004
  • May 24, 2004
I have MM full length SFC welded in. I think they made a big difference in launches. Took out a lot of rattles and squeaks as well.
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
M
Inheriting (and likely restoration of) a 1965 Mustang
  • miniwheats235
  • Feb 17, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 19, 2026
Realmongo
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
