  • SN95 4.6L Mustang Tech
Which sway bar set ?
  • Thread starter Thread starter Rusty67
  • Start date Start date Jul 24, 2007
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 24, 2007
  • Jul 24, 2007
I'm looking at either geting the Eibach front/rear swaybar combo or the Suspension Techniques set. I've done a search and read a lot about the Eibach setup on this forum and it would be a good step for my cars suspension. I havn't seen any posts regaurding suspension techniques and I'm wondering if anyone has any experience with the product line. I talked to a local speed shop guy who told me he use to install them all the time and his customers were very happy with them but he said he can't get the parts anymore for some reason. I checked on summit and they actually sell the front/rear kit for my car. Car is a 2000 Mustang.
My mods:
Mac box upper/lower rear control arms
Eibach Pro Kit springs
KYB AGX all the way around
MM CC plates
Suspension mods I'm considering:
Sway bars
Bump-steer kit
Cobra front A-arm
blacksheep-1
322
Jul 24, 2007
  • Jul 24, 2007
IMHO the front sway bar is already stiff enough, I've run these cars in "stock" class competition (NASA classD) and I feel the front is plenty stuck as it is, especially with the engine weight being so far up front. I'd put a decent set of shocks on the car, lowering springs(Eibach is what I use) install a bigger bar on the rear and use a Steeda bump steer kit on the front to get the steering geometry back up out of the pavement. You will be surprised at the difference just those changes will make. You may also want to find some convertible front end "K" brace and subframe connectors for your car. Even though they are not as good as weld ins they do make a difference (Stock rules).
http://www.steeda.com/products/bumpsteer_kit.php
http://www.steeda.com/products/x2_balljoints.php
http://www.steeda.com/products/steeda_superlite_sport_springs.php
http://www.steeda.com/products/bilstein_strut.php
http://www.hotchkis.net/
http://www.bmrfabrication.com/Mustang.htm
http://www.maximummotorsports.com/
http://www.agentfortyseven.com/racing/index.html
this should keep you drooling for awhile...
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 24, 2007
  • Jul 24, 2007
Are the Cobra front arms really an upgrade at all ? I was under the impression that they have better ball joints in them but I looked up the parts on rockauto.com and they have the same part numbers.
About the ball joints. If I'm going to put in aftermarket ball joints then why don't I step it up to screw in ball joints ? I havn't seen any for these cars, then again I havn't looked that hard.
I'm definately considering a bump steer kit, I was thinking about Baer. Are the Steeda and Baer kits basically equal in quality ? I looked at the MM bump steer kit but I didn't like the bolt with the tapered adaptor.
As for sub-frame connectors, my friend is going to do some custom tubular ones for me at some point. Provably after I swap the v8 in.
Finally, back to the sway bars, any opinion on suspension techniques ?
san~man
O-G
A little grass shack on a big lava rock
Jul 24, 2007
  • Jul 24, 2007
You don't need sway bars. Your stock ones work fine.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 24, 2007
  • Jul 24, 2007
I need to replace my front bushings at a minimum as they are shot. Does anyone make a greasable poly bushing ?
san~man
O-G
Jul 25, 2007
  • Jul 25, 2007
Off the top of my head, I know Energy makes poly, but I don't know if it's greasable. Maybe MM sells a kit too, check their site.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 25, 2007
  • Jul 25, 2007
The MM bushings do not apear to be greasable. I may have to make them myself...
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 25, 2007
  • Jul 25, 2007
If anyone wants to know energy suspension does make a greasable poly front sway bar bushing.
http://www.energysuspension.com/pages/must2.html
tomustang
Psychotic Member
3,434
McLean Hospital
Jul 25, 2007
  • Jul 25, 2007
My mods:
MM CC plates
Sway bars
Bump-steer kit
Cobra front A-arm
Don't waste your money on very little/nothing gain, get a PHB/watts, Full subframes, or dampers for a real improvement
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
