  • 1994 - 1995 Specific Tech
Which Valves?
  • Thread starter Thread starter Guero
  • Start date Start date May 21, 2006
Guero
2,148
May 21, 2006
  • May 21, 2006
http://www.partsamerica.com/ProductList.aspx?PartType=174&PTSet=A&SearchFor=Valves
will these fit my heads? both exhaust and and the intake ones
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 21, 2006
  • May 21, 2006
ummm
Which ones? It says I have to pick a year.
Ok I found them. But IDK so I realy shouldnt be telling you.
Guero
2,148
May 21, 2006
  • May 21, 2006
i have the Trick flow TW Heads. thats why im asking. my bad.
Guero
2,148
May 21, 2006
  • May 21, 2006
oh yeah the ones on the link are for stock heads. i dont know if theres a difference or not.
Zero Signal
2,633
Tucson, AZ
May 21, 2006
  • May 21, 2006
SO did you find messed up valves after your ordeal?
In either case, just call trick flow and find out what springs to get for those, they should tell you exactly which ones.
Guero
2,148
May 21, 2006
  • May 21, 2006
i need the springs to? i thought it was just the valve itself?
Guero
2,148
May 21, 2006
  • May 21, 2006
got this of the trick site... The heads are machined for 2.02" intake/1.60" exhaust valves to build top-end power without sacrificing bottom-end torque. They don’t require flycut pistons for use with cams up to the specifications listed—no other 2.02"-valved head for small block Ford offers these features!
The Twisted Wedge heads are built for heavy-duty use, too. They have .560" thick combustion chamber walls and fire deck for strength without compromising cooling capacity. Additional support risers are strategically located in the water jacket for additional rigidity and head gasket integrity.
Twisted Wedge heads have stock height intake and exhaust ports that allow the use of most OEM and aftermarket intake and exhaust manifolds. Fully assembled heads come with stainless steel valves (intakes are back-cut for improved flow), valve springs, locks, retainers, rocker studs, and guideplates. The heads are also available as bare castings. Heads are sold in pairs. Heads are patented.
that means i can use stock one right?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 22, 2006
  • May 22, 2006
nope you need a 2.02" intake valve and a 1.60" exhaust valve.
Intake Valve Diameter:
2.02"
Intake Valve Angle:
15°
Intake Valve Seat:
Tungsten alloy, 2.087" x 1.800" x .375"
Intake Valve Length:
4.960"
Intake Valve Stem Diameter:
11/32"
Exhaust Valve Diameter:
1.60"
Exhaust Valve Angle:
17°
Exhaust Valve Seat:
Tungsten alloy, 1.657" x 1.400" x .375"
Exhaust Valve Length:
4.980"
Exhaust Valve Stem Diameter:
11/32"
Valve Guide Material:
Bronze alloy, intake and exhaust
Valve Guide Length:
2.00"
Valve Guide Clearance:
.0012" intake, .0016" exhaust
Valve Seals:
Viton, .500" i.d. x .700" o.d. x 11/32" stem
Valve Seat Angles:
37° x 45° x 60°
how many did you mess up? if you bent a lot of them you would be better off buying a set
heres your intake~ TFS-51400211
http://store.summitracing.com/partd...309038+4294908331+4294868549+115&autoview=sku
exhaust~ TFS-51400212
http://store.summitracing.com/partd...908331+4294840126+4294788921+115&autoview=sku
Guero
2,148
May 22, 2006
  • May 22, 2006
dont know im gonna take em off soon. then ill know for sure.
Guero
2,148
May 22, 2006
#10
  • May 22, 2006
  • #10
thanks though. i couldn't find those at summit thats why i asked, but thanks
Guero
2,148
May 22, 2006
#11
  • May 22, 2006
  • #11
Is there a how to on how to change valves? or is it better some one else do it?
urban96
3,464
Syracuse, NY
May 22, 2006
#12
  • May 22, 2006
  • #12
umm.. you would need a spring compressor. but if their bent youll wanna have the guides checked so i would have a shop do it
Guero
2,148
May 22, 2006
#13
  • May 22, 2006
  • #13
what kinda of shop????????
urban96
3,464
Syracuse, NY
May 22, 2006
#14
  • May 22, 2006
  • #14
machine shop
Guero
2,148
May 22, 2006
#15
  • May 22, 2006
  • #15
what you think is a price there gonna charge?????? per valve
urban96
3,464
Syracuse, NY
May 22, 2006
#16
  • May 22, 2006
  • #16
it depends on what they have to do. if their just swaping valves out and checking, not too much. if they have to replace any guides itll cost a bit more but it shouldnt be super expensive.
i remember reading a post u where u said ur mechanic gave u somethign to blow air into the cyls. you could use that to test if you have a bent valve. if you blow air into the cyl (with both valves closed) and u can hear the air rushing out then odds are u have a bent valve.
Zero Signal
2,633
Tucson, AZ
May 22, 2006
#17
  • May 22, 2006
  • #17
Could be anywhere between $6 and $12 per valve to sleeve them. They probably won't charge you anything or at least something small if they all turn out ok.
And to assemble or disassemble heads, it's gonna be around $60 for both heads.
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
