  • SN95 4.6L Mustang Tech
Whistling
  • Thread starter Thread starter 00GTpony
  • Start date Start date Jul 5, 2007
00GTpony
162
  • Jul 5, 2007
I'm getting a whistling noise from my motor..anybody have any idea what it could b?..I only hear it after I rev the car...or if I'm driving and I come to a light and stop then I will hear it for a like 15 seconds...any ideas its driving my crazy
my vaccuum gauge reads 17...... wen i put it in about a month ago it red 15. ( dont no if that has anythin to do with it )
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 6, 2007
  • Jul 6, 2007
Some times the IAC can cause a whistling noise.. check to see if it's the IAC
Green&GoldGT
302
Virginia
Jul 6, 2007
  • Jul 6, 2007
I know what noise you're talking about, mine does the same thing. But I have no clue where it comes from though.
BlueGT4.6
9
Stratford, CT
Jul 6, 2007
  • Jul 6, 2007
Did someone install a supercharger in your car when you weren't looking? Heh..
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 6, 2007
  • Jul 6, 2007
Did you recently install a Gatorback belt? They make a whistling noise. Could also be a failing idler pulley.
G
GettinThere
553
Central Texas
Jul 6, 2007
  • Jul 6, 2007
Did you recently install a new plenum and/or throttle body?
9
98MACH1R
I wanna put it in so bad, please help.
Jun 6, 2005
131
  • Jul 6, 2007
almost 100% its this, same thing happened to me and it drove me up the wall, might be different for you but its sounds like the same thing.
00GTpony
162
  • Jul 6, 2007
Blue gt... i rele wish that happend..... kilgore ... nope
It sounds like its comming from the throttle body tho
JBushman73
172
Roanoke, VA
Jul 6, 2007
  • Jul 6, 2007
Exactly what I thought.
Mike97gt
it doe snot
10,633
Jul 6, 2007
#10
  • Jul 6, 2007
  • #10
one quick way to test if it's IAC related is to slightly hold the throttle open so it come off of idle and then pull the electrical connector and see if the noise stops. You have to hold the throttle open or the engine will stall out.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Jul 7, 2007
#11
  • Jul 7, 2007
  • #11
Mine turned out to be my TB/Plenum combination, although I never figured out where. I used an automotive stethoscope to pinpoint it, and noticed it went away when I would seafoam.
lvmustanggt
721
Las Vegas
Jul 7, 2007
#12
  • Jul 7, 2007
  • #12
I found out few days ago that my C&L upper intake is whistling, now I know nothing is wrong . When I give gas and let go then whistle.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
