Another tip: Hold down the tripmeter button while starting the car and release it when the odometer reads "test" - you can push the button and cycle through the gauges. It will show RPM's for setting the needle correctly. Also if you drive around the block with the clear bezel off you can set it to "eng" and get your speed so you can replace the needle on the speedometer.
Might help.
Jay
