  • 1994 - 1995 Specific Tech
who has done it? AWD Aerostar aluminum driveshaft
  • Thread starter Thread starter Dan95-5.0
  • Start date Start date Jun 20, 2005
Dan95-5.0
1,110
Manitoba, Canada
Jun 20, 2005
  • Jun 20, 2005
i've done a search and found all the posts but never got a answer from someone who has done it. i heared people with many different answers like you have to cut it, get it balanced, change yokes, and u-joints.
i found a awd aerostar Eddie Bauer eddition thats getting parted out. i want to get the driveshaft if its aluminum and put it in my car but want to know what i'm getting into before doing it.
u-joints and yokes wont be a problem but shortening it would be a waste of time and then i would just buy a FMS one.
who has "done it"? what was needed to get it to work?
thanks
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 20, 2005
  • Jun 20, 2005
I ve heard you need to change yokes and by the time your done its almost the price of a FMS one or someting.
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Jun 21, 2005
  • Jun 21, 2005
Never even heard of this Dan...I'd just buy the FMS one
CManT1914
3,172
Killeen, Texas
Jun 21, 2005
  • Jun 21, 2005
There's gotta be a reason why I've never heard of this before, like maybe it's too complicated and not worth it. I'd just buy a new one.
K
Kid Capri
275
Jun 21, 2005
  • Jun 21, 2005
I bought three of them for 50.00 each, and sold one for a hundred bucks. I will tell you guys that there is a couple of things that you need to be aware of when, and if you decide to go in this direction. The driveshaft you need must be from a 4wd aerostar and have the factory recall driveshaft in place. There is a silver sticker somewhere on the shaft with the #s F79Z-4602-AA.
The drive shaft has a smaller o/d, I believe the MS unit is 3.5" possibly 4", whre the aerostar unit is 3". If you have issues with your exaust rubbing on your MS unit, this may help you out, and the length is exactly the same as the one I pulled from my cobra @ 45.5"(center U joint cap to center U joint cap).
This is what you need to do to make it work. You will need your old yokes, both sides from your stock steel unit, and you need to put those on the aerostar unit. You will also need a universal joint that accomidates using the yokes from your mustang which is also a larger O/S diameter than the aerostar unit, to the smaller O/S diameter of the aerostar unit. Part # from Autozone is 1-0134, around five dollars each or you can cross reference for a different brand. Last but not least you must be very careful when removing the old U joints and yokes from the aerostar unit, they are in place really, really well. Do not damage the area that hold the U joint snap ring in place while removing the yokes from the aerostar unit, take your time. Reinstall your stock yokes to the aerostar unit, grease up your U joints and you should be set.
Dan95-5.0
1,110
Manitoba, Canada
Jun 21, 2005
  • Jun 21, 2005
sweetness man. thanks for giving me all that info.
this is the first time that i've read this from someone who has actually done it.
i'll give the guy a call tommorow to see if its available still
thanks
Dan95-5.0
1,110
Manitoba, Canada
Jun 21, 2005
  • Jun 21, 2005
here are the specs on those u-joint #1-0134
3.622" yoke width / 1.063" cup dia.
Dan95-5.0
1,110
Manitoba, Canada
Jun 22, 2005
  • Jun 22, 2005
what brand were those u-joints that you got from autozone? we dont have autozones up here in canada.
K
Kid Capri
275
Jun 25, 2005
  • Jun 25, 2005
The brand of U joints were PDQ.
C
clintjackson
37
#10
  • Aug 9, 2011
  • #10
And I thank u for the info also. I found that same unit from my local pull a part for 13.99 plus 3.99 core. It has that stick you descibed. I feel much better knowing the specifics.
SableSal
295
Fresno, Californ-I-A
Aug 9, 2011
#11
  • Aug 9, 2011
  • #11
I have done this mod and currently have it in the Stang for about one year now. Works perfectly fine and was less than $60 to get it setup. I've ran it pretty fast with that DS and it works nicely!
T
turbogt
723
Montana
Aug 9, 2011
#12
  • Aug 9, 2011
  • #12
WOW.. I've never heard of this either, but sounds perfect for me because I have VERY little clearance around my DS with my exhaust..
SableSal
295
Aug 11, 2011
#13
  • Aug 11, 2011
  • #13
Yup, the tube is thinner and would fit great with a side exhaust setup. Wanna swap DS? Hehehe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
