Female Torx E-8 socket is what you need.
Use penetrating oil 24 hours before you try to remove it, and be generous. It wouldn't hurt to spray it every 6 or 8 hours until you are ready to remove it, then spray it again, and remove the bolt and carefully slide out the abs sensor. Good luck.
Scott
